Old 06-05-2015, 09:05 AM   #1
Tutran
Drives: 2013 Camaro 1lt
Zl1 brakes on v6 camaro
Was searching and couldn't find much on this. Was wondering of anyone had info on putting zl1 brakes or cts-v brembos only a v6 I know the ss are almost just bolt on with a few trimming, but I was just curious because I have acess to some and wanted to see if I should pull the trigger on them if it's an easy swap
Tutran is offline   Reply With Quote
Old 06-05-2015, 10:28 AM   #2
Synner
Drives: cars
Backing plates, hoses, calipers, rotors, and caliper bolts. Easy as pie.
Old 06-05-2015, 10:53 AM   #3
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
http://www.camaro5.com/forums/showthread.php?t=348133
Followed this list and the install was fine.
Lil' Nasty is offline   Reply With Quote
Old 06-05-2015, 03:44 PM   #4
Tutran
What about brake lines and the master cylinder? Did you have to change those? And how much was your total if you don't mind me asking?
Old 06-05-2015, 04:14 PM   #5
JMT
JMT's Avatar
Drives: 2013 1LT
I am using stock master cylinder and is fine, as others have said trim the backing plates on the rear and save a bundle.
JMT is offline   Reply With Quote
Old 06-05-2015, 04:20 PM   #6
Tutran
I'm just worried about someone stating it may not brake at all due to lack of fluids because a it requires more
Old 06-05-2015, 10:55 PM   #7
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Not sure what they are saying, but you can install them on a V6 and they will work. The biggest issue is making sure you wheels have adequate clearance for the new calipers.
Good luck.
brakes, camaro, zl1
