Old 06-10-2015, 07:24 PM   #1
Homeless Man
Homeless Life Chose Me
Homeless Man's Avatar
Drives: LS3 (sold 4/21)
Arrow Rusted Rotors Tips On Painting?
So when I paint my calipers I'm also gonna paint the rotor hats. They have a little rust on them just don't want it to get any worst. I'll hit it with scotch Brite pad then brake cleaner like the calipers. For u guys that do it how many layer and does it rust through after a period of time? I have the VHT Caliper Primer is that enough 3 layers so it won't rust through. I also want it to be the same color as the metal so do u think that primer will work well since I already have it or should I buy a color?
Homeless Man is offline   Reply With Quote
Old 06-10-2015, 10:24 PM   #2
bradshaw
bradshaw's Avatar
Drives: 2010 LS3 2SS M6
Look here: http://www.camaro5.com/forums/showthread.php?t=344735
bradshaw is offline   Reply With Quote
Old 06-10-2015, 11:20 PM   #3
Homeless Man
Originally Posted by Comrando View Post
You should grab some plastic bags out of the dumpster you sleep in and cover the rotors and steal some black spray and paint graffiti on walls.
I'll make sure to graffiti all over your car if I ever see it
Old 06-11-2015, 12:57 AM   #4
VChula
SoCal C5 Family Member
VChula's Avatar
Drives: 1996 Z28 SS & 2014 ZL1
The paint you show in the picture will not hold up temperature-wise.
You will need this line of VHT paints instead:
http://www.vhtpaint.com/products/caliperpaint/
Just follow the steps shown on the web page and you will be good to go.
I would definitely not just use the primer. The primer will absorb moisture if it is not sealed - no mater how many coats you apply.
Vance Chula -
1996 Camaro Z28 SS #1688
2014 Camaro ZL1 Coupe #1956
VChula is offline   Reply With Quote
Old 06-11-2015, 01:35 AM   #5
Vroom_vroom
The gritos pollo!!!
Vroom_vroom's Avatar
Drives: Like a idiot
You are a funny ****er I must give you that lmao
https://www.youtube.com/@FredJrsGarage
‘19 Silverado 3500 dmax
‘77 trans am
‘63 c2
Shopping for more Camaros
Vroom_vroom is offline   Reply With Quote
Old 06-11-2015, 01:58 AM   #6
Homeless Man
I'm pretty sure if my rotors get hotter than 550 degrees then I have other problems to worry about other than paint. But I guess I will get VHT caliper paint then since you said it's not sealed.
Old 06-11-2015, 01:59 AM   #7
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 06-11-2015, 02:33 AM   #8
Homeless Man
I'll give you a quarter if you don't.
Ok Ned Flanders
Old 06-11-2015, 02:41 AM   #9
Hetfield03
Hetfield03's Avatar
Drives: 2010 2LT/RS Black/IOM
Okally dokally neighborino.
ZL1 Factory Reproduction Wheels, Airaid CAI, MRT V 2.0 Axle Back Installed by PIE Customs, Painted IOM Rally Stripes, Bowties by Danny Taylor Louisville KY, IOM Engine Cover and Fusebox Cover by River City Creations and Lighting San Antonio TX.
Hetfield03 is offline   Reply With Quote
Old 06-11-2015, 02:49 AM   #10
Homeless Man
Ok I'll get grey paint high temp paint or something for the rotors. I bought the primer because I'm gonna use that as the first layers before I paint calipers.
Old 06-11-2015, 06:19 AM   #11
snarky
ultracrepidarianism
snarky's Avatar
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport
paint your rotors? um.. okay.
snarky is offline   Reply With Quote
Old 06-11-2015, 06:44 AM   #12
NTENSITY
NTENSITY's Avatar
Drives: 2015 Camaro 2SS 1LE Package
He's not painting the actual rotors. He's painting the hats that sit in the middle of the rotor. The black part in the image is what is getting painted.
NTENSITY is offline   Reply With Quote
Old 06-11-2015, 07:52 AM   #13
Smokin19
Drives: 19' ZL1 A10, w/pdr
Here is what I used on the rotors. It's the Dupli-cover high temp engine enamel. Have had no rusting or problems peeling.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/Gesi cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
Smokin19 is offline   Reply With Quote
Old 06-11-2015, 05:13 PM   #14
Homeless Man
I see u painted the edges too. I thought about that but decided against it since I'm leaving the rotor on.
I still don't get how everytime someone brings up painting the rotor hats that rust, some people actually think we mean painting the braking surface
