Old 06-15-2015, 08:33 PM   #1
BLK MARO
BLK MARO's Avatar
Drives: 2013 1SS/RS CAMARO
Rear end movement
The rear of the car is moving all over the place when I get on it. I have to let out of every time because its moving so much. What is my issue? my suspension mods are bmr trailing arms, bmr toe rods, bmr sway bars and LG G5 coilovers. could it be my alignment?
BLK MARO is offline   Reply With Quote
Old 06-15-2015, 08:35 PM   #2
Bizaro
Drives: 2015 Redhot 1LE
what tires u got
Bizaro is offline   Reply With Quote
Old 06-15-2015, 08:48 PM   #3
BLK MARO
BLK MARO's Avatar
Michelin pilot super sports
Old 06-15-2015, 09:09 PM   #4
43Camaro
43Camaro's Avatar
Drives: [COTW 8/3/15] 2010 Camaro SS L99
You have gears, blower or any other power adders?
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable!
https://www.camaro5.com/forums/showthread.php?t=418273
43Camaro is offline   Reply With Quote
Old 06-15-2015, 09:20 PM   #5
BLK MARO
BLK MARO's Avatar
3:91 gears, cam, headers. 455rwhp
Old 06-15-2015, 09:31 PM   #6
oachalon
Drives: 2010 Camaro 1SS
Have you done a cradle bushing upgrade?
2010 1SS/RS LS3 M6
Edelbrock E-Force Supercharger, 3.00" Pulley, Roto-Fab CAI, Stainless Power LT Headers, LPE Dual Fuel Pump, ID850's, Custom Grind Cam, Katzkin Leather/Suede Interior 630RWHP mustang dyno.
oachalon is offline   Reply With Quote
Old 06-15-2015, 09:37 PM   #7
BLK MARO
BLK MARO's Avatar
Not yet. Been looking into them
Old 06-15-2015, 10:03 PM   #8
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
A buddy of mine had the same issue, it was the BMR bushings in the toe-links/trailing arms (scroll down to post #39)...http://www.camaro5.com/forums/showth...=315220&page=2
POWERFREAK is offline   Reply With Quote
Old 06-16-2015, 01:39 PM   #9
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
I was going to mention it's probably a bad bushing as well. Those poly bushings are great, but when they wear out it's more noticeable than a softer rubber bushing.
This would be the first issue with poly bushings i've seen on the forum.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 06-16-2015, 02:51 PM   #10
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Any upper control arm bushing upgrade?
Nighthawk89 is offline   Reply With Quote
Old 06-16-2015, 03:50 PM   #11
BLK MARO
BLK MARO's Avatar
I have no bushing upgrades on the car. looking into rear cradle bushings and trailing arm bushings
Old 06-16-2015, 06:05 PM   #12
POWERFREAK
I.AM.
POWERFREAK's Avatar
It's the bushings that came in the bmr parts. If not, i would check the alignment.
Old 06-16-2015, 06:25 PM   #13
BLK MARO
BLK MARO's Avatar
Im going to do the cradle bushings and trailing arm bushings and do a alignment just to make sure.
Old 06-16-2015, 07:01 PM   #14
1969to2010
The Man in Black
1969to2010's Avatar
Drives: 1969 Camaro 2010 Camaro 1SS
Do an alignment first then if you are still having the issue contact bmr asap. Im the op of the other thread. Let my nightmare help you. Trust me start there.
Was the car aligned after the new suspension parts were installed ?
1969to2010 is offline   Reply With Quote
