Old 07-06-2015, 07:56 PM   #1
domchevelle
Drives: 2010 camaro 2SS
Cool E Force problem ?
Hello i'm from Montréal, Québec. I bought a 2010 2SS camaro last fall. I tried my car in dragway and my best time was : 13.44 at 109.29 mph. At this time my car was stock power train.
This winter, i installed a edelbrook e force. I ran my car for a couples miles and everthing was good.
Last week, i tried my new set-up and my best time was : 13.27 at 108.89 mph with all the same power train except the eforce and the ls9 cams.
Wath is the problem ???
Today i verified the pressure (psi) = 7 psi
Do you think it could be the competition mode ??
Thank's
Dominic Gladu
domchevelle is offline   Reply With Quote
Old 07-06-2015, 08:26 PM   #2
bayarea408
bayarea408's Avatar
Drives: T
you need to give us a time slip to really gauge how your taking off and what it looks like.
Your car is trapping less then what your stock car is trapping. Does the car feel drastically faster? It surely should...
list your mods and what type of power did the setup make?
Are you automatic or are you manual?
somethings wrong if you strap on a blower and cam and you end up with a slower trap speed. that doesnt make any sense.
bayarea408 is offline   Reply With Quote
Old 07-06-2015, 08:31 PM   #3
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
There are so many possibilities. Was the car tuned ? If you need someone good to look at it in Montreal, message me and I will help you out.
Meanwhile, list more details to get some suggestions...
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 07-06-2015, 08:32 PM   #4
Reelgrinder
Drives: 2016 SS
Probably traction.. what are your dyno numbers?
2016 SS with Eforce 2300
Borla Headers
Borla Atak
Reelgrinder is offline   Reply With Quote
Old 07-06-2015, 08:34 PM   #5
realcanuk
realcanuk's Avatar
Traction would hurt times, but not lower the trap speed like that. Something else at play there.
Old 07-06-2015, 08:48 PM   #6
domchevelle
Thank,s for you reply.
my cars are all stock exept :Eforce and LS9 camshaft.
6 speeds and stock gear (3:42) and PZero tire ,
the tune are From SCT (Edelbrock)
i take picture of my time slip but i dont know how to put them here :(
Old 07-06-2015, 09:10 PM   #7
bayarea408
bayarea408's Avatar
Drives: T
SCT? get yourself a REAL tuner with a REAL tune.
Old 07-06-2015, 09:13 PM   #8
domchevelle
What is the best tuner for my ,to day i looking for EFIlive ,it is good ?
Old 07-06-2015, 09:14 PM   #9
realcanuk
realcanuk's Avatar
I tune my car with hptuners..... but it is a personal preference. EFI live is good too.
Old 07-06-2015, 09:15 PM   #10
LSXBumblebee
LSX Bumblebee
LSXBumblebee's Avatar
Drives: 2014 LSX Camaro
Find a shop that can tune. Also, how much HP do you have? Where is your timeslip? E-Force stock is around 500whp, maybe you need bigger injectors, and ZL1 pump. There are a lot of things that could help. Dyno numbers can really help us see what's going on too.
LSX 427 | ZL1 Driveline | LSA Blower | Stage 3 BTR PD Cam | 85 lb. Injectors | ZL1 Pump | ADM FPCM | Pulley
LSX Bowtie Block Blueprinted by Gilroy Automotive Machine | Assembled by LSXBumblebee/Arnold Crocker
Build Thread: LSX_Bumblebee's 2014 LSX Camaro 2SS/RS Convertible
LSXBumblebee is offline   Reply With Quote
Old 07-06-2015, 09:24 PM   #11
Unreal
Drives: 2006 Z06
Either way, should have picked up 100rwhp over stock. Tune/etc will help, but that isn't the problem.
I also say traction. 500rwhp and pzeros isn't going anywhere fast.
Nick
Corvette Z06 -1200ish rwhp
Old 07-06-2015, 09:24 PM   #12
forklord
forklord's Avatar
Drives: 2010 2SS
That cam wont do much for ya really. The canned tune is extremely conservative. But you should be getting a better trap speed like the guys said regardless. Is it running ok?? Maybe theres an issue with the intercooler locked up and getting major heatsoak? Vacuum/air leak? Youd probly throw a code tho...just throwing stuff out there.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 07-06-2015, 09:25 PM   #13
forklord
forklord's Avatar
Drives: 2010 2SS
In saying that ive never had an issue with my coolant flowing after flushing the system 4 times when i had an eforce.
I have a rotofab intake made for the eforce too of youre interested. Give you a great deal since youre in canada too.
Old 07-06-2015, 11:56 PM   #14
robsbandit
robsbandit's Avatar
Drives: '14 Camaro 1LE and '67 Camaro
I'm interested as well and trying to sort out a similar situation. I have the Magnuson Heartbeat supercharger and I am at 530whp in a '14 1LE. My trap speed was pretty consistent at 113mph with 8 runs. Air temp was about 75deg and the track is at about 1,200ft above sea level. I was a bit disappointed and felt it should have been faster. My solution is 1-7/8" headers, a smaller pulley and a new tune from a better tuner. Lol!
robsbandit is offline   Reply With Quote
