Old 07-25-2015, 07:27 PM   #1
ZYBORG
Lets roll...
ZYBORG's Avatar
Drives: 14'
No-lift-shift on 1LE
I know the ZL1 and ZR1 both have the no-lift-shift feature but does the 1LE have that ability as well?
I have heard some say that this is a feature only made available to the 14' and up 1LE, anyone know?
ZYBORG is offline   Reply With Quote
Old 07-25-2015, 08:50 PM   #2
Airway Monkey
Airway Monkey's Avatar
Drives: 2015 2SS/1LE
Subscribed.
Airway Monkey is offline   Reply With Quote
Old 07-25-2015, 09:06 PM   #3
s9779
s9779's Avatar
Drives: 2015 2ss 1le
1les do not have no lift shift.
s9779 is offline   Reply With Quote
Old 07-25-2015, 10:50 PM   #4
toehead93
Drives: 2014 2SS/1LE
I did't think any of those cars you mentioned have no lift shift. As far as I know the rev match and no lift shift is a C7 and gen6 only feature. I did a quick search and found ZL1 articles about it so still looking for more info
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 07-25-2015, 10:56 PM   #5
ZYBORG
Lets roll...
ZYBORG's Avatar
Drives: 14'
ZR1 and ZL1 have NLS, it's a fact. Never mentioned anything about the Z28.
Im trying to find out about the 1LE, I have heard/read yes and no...
Old 07-25-2015, 11:04 PM   #6
s9779
s9779's Avatar
No lift shift is only available on the ZL1. Then you push the clutch in the computer uses the drive by wire control to cut the throttle for you. If you leave the gas pinned on a 1le you just going to power shift the hell out of her. Rev matching down shifts are something completely different and not avaliable on any 5th gen.
Old 07-26-2015, 12:23 AM   #7
PapaKlutch
PapaKlutch's Avatar
Drives: 2015 Camaro SS/1LE
Z/28:
http://www.camaro5.com/forums/showthread.php?t=413313
2015 2SS/1LE/RECARO/NPP/RS/NAV
PapaKlutch is offline   Reply With Quote
Old 07-26-2015, 12:27 AM   #8
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
Originally Posted by s9779 View Post
No lift shift is only available on the zr1. Then you push the clutch in the computer uses the drive by wire control to cut the throttle for you. If you leave the gas pinned on a 1le you just going to power shift the hell out of her. Rev matching down shifts are something completely different and not avaliable on any 5th gen.
Not so, the ZL1 has it for sure. I've used it.
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 07-26-2015, 12:39 AM   #9
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Yeah no 1LE has it. Only ZL1 and ZR1 have it to carry boost into the next gear.
Old 07-26-2015, 12:30 PM   #10
s9779
s9779's Avatar
Are you talking about the tap shifter on automatic zr1s.
Old 07-26-2015, 12:53 PM   #11
PapaKlutch
PapaKlutch's Avatar
No Lift Shift on the manual transmissions.
A part of Performance Traction Management system and allows the computer to keep the revs up without "over rev" to keep the supercharged cars on the boost during shifting.
Old 07-26-2015, 01:04 PM   #12
ZYBORG
Lets roll...
ZYBORG's Avatar
Drives: 14'
ZL1 and ZR1 LC and NLS
http://youtu.be/kr_1nOPrpgQ
Old 07-26-2015, 03:00 PM   #13
Green Machine
Always Workin
Green Machine's Avatar
Drives: 2021 Mazda MX-5
1LE does not have it, although it may have the ability to turn it on through EFILive or HPTuners.
2023 Vivid Orange 1SS 1LE 6MT
Arrived 8/31
Purchased 9/3
2018 1SS 1LE, HyperBlue Metallic (Sold)
2014 1SS 1LE, Black, Twin Turbo (Sold)
Green Machine is offline   Reply With Quote
Old 07-27-2015, 11:27 PM   #14
Cornercarver
Drives: 2011 2SS/RS M6
Everyone I know calls it power shifting. Been doing it for a long time, doesn't seem to bother the car. Mine is an SS and doesn't have the NLS programming or anything but it still can be shifted without lifting through third gear for sure. I've done it. It definitely hits the rev limiter for a split second
The ZL1 and ZR1 are both supercharged and I would bet that the programming is setup differently giving them a true NLS program that allows them to keep boost while shifting. Mine isn't boosted so I don't loose any boost even if the car pulls timing and hits the rev limiter.
May not be optional but many I know do it and I have also...
Cornercarver is offline   Reply With Quote
