![]() Drives: 2015 ZL1 Bright Yellow Join Date: Apr 2015
Installation order?
Hello all,
I've got a 2015 ZL1 and I'm planning to order a Roto-Fab CAI as well as an Elite E2 Catch Can. (Single exit, no check valve, etc.) I was just wondering if I should be worrying about the order of installation. i.e. Should I install the RotoFab first and then the catch can, or vice versa, or the order doesn't matter at all? Not sure if there is any correlation between the two. Just to let you know, I will not be installing these two items on the same day. One might be 2-3 weeks after the other. I'm thinking the order doesn't matter, but just wanted to double check... Thanks! |
![]() Drives: 13 blue ray zl1 Join Date: Apr 2015
it doesnt matter.
stock for now blue ray 13 zl1 m6
04 cts-v. cammed, headers, exhaust, intake, suspension 92 lexus sc300. singled 2jzgte swapped 07 tbss basically stock 00 built z28. 520 rwhp, 5.7, no power adders |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
doesn't matter, however, Rotofab first then catch can makes more sense to me.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Mar 2013
2018 Garnet Red ZL1 conve
Drives: 2013 & 2018 ZL1 vert Join Date: May 2009
New car
Yes, Roto-Fab first so you can listen to that beautiful blower whine! Congrats on the new ride!!
#6 |
Rumblebee
Drives: ZL1 Rally Yellow Join Date: Apr 2013
Do the catch can first, why let more gunk into the engine than necessary?
#7 |
#8 |
The rotofab install requires you to move the stock "clean side" little plastic catch so it would make more sense to do the Rotofab first. Otherwise, you may have to change the length of a hose, etc. These are minor quibbles...it really doesn't matter.
#9 |
Got you... Cool, thanks for the input guys, appreciate it.
#10 | |
![]() Drives: 2015 ZL1 Blue Velvet Metallic Join Date: Mar 2015
Respectfully, what are you talking about? CC and CAI are not linked on a ZL1, unless I've totally missed something. They are completely independent of each other, with respect to installation.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
#11 |
On a most typical catch can setup, you are correct. Only a "dirty side" catch is necessary which uses the valley & TB hookup. Some people run the "dual valve" unit that has a clean side hookup as well from the CAI that ditches the factory plastic "clean side catch" Sorry for not being specific.
#12 |
like this:
#13 |
No need to be sorry, I'm the one who didn't know.
#14 |
![]() Drives: Impala Join Date: Aug 2015
I would have ordered RotoFab first and then catch can.
| Tags |
| cai, catch, catchcan, order, rotofab |
