Old 08-16-2015, 07:39 PM   #1
jboutari
Drives: 2010 Camaro ss/2ss/rs
2010 camaro ss problems
Hello everyone,
I'm new to this forum and to camaro. I bought a used 2010 2ss/rs with 46000 miles on it. Now it has 59000 miles. Few weeks ago I started to have a hesitation/jerking and stalling when I come to a stop but still no check engine light yet. At idle the rpm goes up and down before it stalls. When the cil finally came on I took it to auto zone and had the codes read. I got po102 and po113. I replaced both sensors maf and map but that didn't fix it. After 3 starts or trips the cil will turn off but the symptoms remain. Did that few times until today I took it back to read the codes again, it had, po102,107,113,300,352,353,354,355,and 358. I had replaced the spark plugs and wires 2 weeks ago and I do have spark from the coils. Anyone had a similar problem here? Is it the fuel pump? Any help is really appreciated.
Thanks
jboutari is offline   Reply With Quote
Old 08-16-2015, 08:33 PM   #2
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
Originally Posted by jboutari View Post
Hello everyone,
Thanks
Does your car have any modifications? Also, could it be a bad spark plug since you just changed them?
Check out my build thread
Old 08-16-2015, 09:37 PM   #3
jboutari
Flow master mufflers. The new spark plugs didn't help with symptoms. I checked for vacuum leaks but found none. It gets worse with traffic.
Old 08-16-2015, 10:54 PM   #4
10 Silver Bullet
10 Silver Bullet's Avatar
Drives: 2010 Silver SS2
Its your weak MAF sensor, same thing happened to me.
10 Silver Bullet is offline   Reply With Quote
Old 08-16-2015, 10:55 PM   #5
10 Silver Bullet
Also need to use 90+ octane fuel and do the fuse pull to reset the octane table.
Old 08-16-2015, 11:16 PM   #6
jboutari
Do you really think it's the maf? I tried two from autozone, duralast and dorman but those didn't fix it. Do you recommend a certain brand? And I did the fuse pull and that didn't fix the problem. But I'll do it again later.
Old 08-17-2015, 12:34 AM   #7
lawdog
Drives: 2010 SSII w RS & Sunroof Yellow
Location: West Suburbs of Chicago, in a Courthouse Somewhere
When is the last time you cleaned your throttle body inlet ? Get some good old fashioned gum out and push open the butterfly and clean the edges all the way around. With the car OFF of course. Could be a faulty idle control
lawdog is offline   Reply With Quote
Old 08-17-2015, 11:49 AM   #8
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Could be a weak maf, could be bad gas (what gas station and what grade fuel do you use?), could be a bad injector, but i'd imagine that would throw a code quicker, as well as a misfiring spark. Why not have the dealer diagnose it instead of just tossing parts at it? Could be cheaper in the end
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 08-17-2015, 06:28 PM   #9
jboutari
It all started when my wife put race track gas in it. But few weeks ago, since then it's been all 93 octane from shell or chevron. I did the fuse pull but that didn't fix it. I'm gonna have to take it to the dealer to diagnose it guess.
Old 08-17-2015, 08:56 PM   #10
lawdog
Well you should have said that in the first place, LOL what octane was the fuel she put in it.
Old 08-17-2015, 09:04 PM   #11
jboutari
89 octane. But you would think after few fill ups of 93 octane and the fuse pull overnight it would run fine.
