Old 08-31-2015, 10:03 PM   #1
Tie Rod
Drives: 2011 Camaro 2SS/RS
1LE Help
Been of it for awhile but now have the time and money to get a new Camaro. Can someone please tell me what a 1LE is and what years it was made Sorry I found out
Tie Rod is offline   Reply With Quote
Old 08-31-2015, 10:09 PM   #2
ZYBORG
Lets roll...
ZYBORG's Avatar
Drives: 14'
To keep it simple, the 1LE is a track focused camaro. Think of it like a big go-kart. Best $3,500. I have EVER spent.
ZYBORG is offline   Reply With Quote
Old 08-31-2015, 10:30 PM   #3
ICTsccaCamaro
Drives: 2018 ZL1 1LE
2013-2015 for 1LE
2014-2015 if you want the refresh front and rear end and heat extractor hood
2013 if you want to keep the 2010-2013 body style
2014-2015 for RECARO seat option
ICTsccaCamaro is offline   Reply With Quote
Old 09-01-2015, 08:38 AM   #4
Hilflos
Drives: 2015 1SS / RS NPP
For reference, the parts list for the suspension components that are changed / upgraded with the 1LE package;
2014 1LE Track Pack(V8)…………………….……….....23123397
The kit includes:
Front Stab Bar Asm (bar, links, bushing, clamp, nut)....22812942(1)
Rear Stab Bar Asm (bar, bushing, clamp, bolt)……......22786260(1)
Rear Stab Bar Link……………………………………......22761221(2)
Front Strut Asm, LH (strut, spring, mount)……………...22812984(1)
Front Strut Asm, RH (strut, spring, mount)……………..22812985(1)
Rear Shock…………………………………………….......23115372(2)
Rear Shock Mount, LH…………………………………....22922445(1)
Rear Shock Mount, RH…………………………………...22922446(1)
Rear Toe Link……………………………………………....22845487(2)
Nut-FRT STAB HYD SHF Link.......................................1151607 8(2)
Emblem-F/End UPR Tie Bar..........................................22942 442(1)
Nut-FRT SUSP Strut MT................................................ 11569638(2)
Nut-RR S/ABS (UPR)............................................. ........11516078(2)
Installation Instructions………………………………….. ..23123399(1)
2014 1LE Track Pack(V6 )…………………….………......23123398
The kit includes:
Front Stab Bar Asm (bar, links, bushing, clamp, nut)......22812942(1)
Rear Stab Bar Asm (bar, bushing, clamp, bolt)……........22786260(1)
Rear Stab Bar Link……………………………………….....22761221(1)
Front Springs........................................... .........................92245257(2)
Front Strut Asm, LH (strut, spring, mount)…………….....22812984(1)
Front Strut Asm, RH (strut, spring, mount)…………….....22812985(1)
Rear Shock………………………………………………......23115372(2)
Rear Shock Mount, LH…………………………………......22922445(1)
Rear Shock Mount, RH…………………………………......22922446(1)
Rear Toe Link……………………………………………......22845487(2)
Nut-FRT STAB HYD SHF Link.........................................11516 078(2)
Emblem-F/End UPR Tie Bar............................................229 42442(1)
Nut-FRT SUSP Strut MT................................................ ..11569638(2)
Nut-RR S/ABS (UPR)............................................. ..........11516078(2)
Installation Instructions(V6)..…………………………….....23123400(1)
Installation Instructions(V8)..…………………………….....23123399(1)
For comparison, here's last year's numbers:
2013 1LE Track Pack……………………….………............231023311
The kit includes:
Front Stab Bar Asm (bar, links, bushing, clamp, nut).........22812942(1)
Rear Stab Bar Asm (bar, bushing, clamp, bolt)……...........22786260(1)
Rear Stab Bar Link………………………………………........22761221(2)
Front Strut Asm, LH (strut, spring, mount)……………........22812982 (1)
Front Strut Asm, RH (strut, spring, mount)……………........22812983 (1)
Rear Shock……………………………………………….........22981391 (2)
Rear Shock Mount, LH………………………………….........22922445 (1)
Rear Shock Mount, RH………………………………….........22922446 (1)
Rear Toe Link…………………………………………….........22845487 (4)
Rear Cradle Bushing, Front…………………………….........20941932 (2)
Rear Cradle Bushing, Rear……………………………..........20941933 (2)
]Installation Instructions…………………………………........23102312 (1)
From here, thanks Rocky1974.
Package also includes forged wheels 20 x 10 up front, 20 x 11 in back 285/35 20's, if I recall correctly, on all four corners, different gearing within the transmission, 3.91 rear end gears, a strut tower brace, short throw shifter, some interior differences (flat bottom steering wheel and alcantara covered steering wheel and shifter). I probably left one or two other things out too.
It is ridiculously good value for the money. The wheels alone are worth a significant chunk of the $3500.00 and the suspension components detailed above sell for $1500.00, just for the parts, to folks who'd like to upgrade their SS (like me) or V6.
Just the suspension componentry was well worth the money, and if I'd found this forum before purchasing the car, rather than after, I would have gone for the whole package. As it is, by the time I get new wheels and tires, I'll have spent well over the package price to replicate it.
Hilflos is offline   Reply With Quote
Old 09-01-2015, 09:32 AM   #5
CTSVBiggie
CTSVBiggie's Avatar
Drives: 2013 1LE
You can get the Recaros in 2013s I thought?
It takes the SS and makes it sharper and harder in all the right ways.
>>>>>>>>>>>MUST READ DISCLAIMER<<<<<<<<<<<<
2013 Crystal Red Tint Coat - 2SS RS 1LE
CTSVBiggie is offline   Reply With Quote
Old 09-01-2015, 09:33 AM   #6
CTSVBiggie
CTSVBiggie's Avatar
Drives: 2013 1LE
The trans and diff and steering wheel and shifter and wheels and fuel pump are all out of the ZL1. All significant upgrades.
Old 09-01-2015, 10:15 AM   #7
SWAG1LE
SWAG1LE's Avatar
Drives: 2013 1LE
A bit more detailed list of EXACTLY what a 1LE has:
• Tremec TR6060-MM6 (different gearing than Tremec TR6060-M10)
• Air-to-Liquid Transmission Cooler
• ZL1 short-throw shifter
• 3.91 axle ratio
• Larger, 27-mm solid front stabilizer bar, and 28-mm solid rear stabilizer bar
• Higher-capacity rear-axle half shafts
• Strut tower brace
• Forged Wheels 20x10 Front, 20x11 Rear
• 285/35ZR20 Goodyear Eagle Supercar G:2
• 1LE-specific Monotube shocks
• ZL1 wheel bearings, toe links and rear shock mounts
• ZL1 high-capacity fuel pump and additional fuel pickups
• Front Splitter
• ZL1 flat-bottom steering wheel
• Electric power steering (all 2013+ Camaros)
• close ratio manual transmission that has higher final drive (3.91 vs. 3.45)
• air-to-liquid cooling system lifted from the ZL1 (trans and oil coolers)
• 20-inch wheels covered in Goodyear Eagle Supercar G:2 tires, 285 on all 4 corners
• Improved wheel bearings (zl1)
• Improved toe links
• upgraded sub-frame bushes
• Better rear shock mounts
• rear monotube shocks
• thicker antiroll bars(27mm front, 28mm rear)
• strut-tower bar
• beefed up the rear-axle half-shafts
• ZL1's high-capacity fuel pump and additional fuel pickups were also added to prevent fuel starvation in hard-cornering situations.
• matte-black hood
• functional front splitter
• rear spoiler
• Oil catch can
• red Brembo brake calipers
• ZL1's flat-bottom, microfiber-covered steering wheel
• short shifter topped with a microfiber shift knob.
Current: PFADT Drop Springs/ZL1 Rock Guards/SLP Skip Shift Elim./DRAKE Bowtie Delete/ELITE Catch Can/XPEL Clear Film/CORSA ZL1 Cat Back/Z28 CAI
SWAG1LE is offline   Reply With Quote
Old 09-01-2015, 10:23 AM   #8
Shutudwn
Drives: 2004 Ford Mustang Cobra
Basically a N/A ZL1. I bought mine for 35k with 21k km. For the money they are tough to beat. Get one and you will not be disappointed.
Shutudwn is offline   Reply With Quote
Old 09-01-2015, 10:33 AM   #9
CTSVBiggie
CTSVBiggie's Avatar
Drives: 2013 1LE
I can disagree. i fyou plan to drag race. You will be disappointed. Otherwise its teh best car ive owned dynamically. and maybe aesthetically as well. But my older CTSV1 is hard to beat there.
Old 09-01-2015, 11:33 AM   #10
nvydvr
nvydvr's Avatar
Drives: 2015 Red Rock ZL1
Okay, this might be a stupid question, or maybe I didn't read this right but... You can get a V6 1LE??? Or are those just components for those who want to upgrade their V6 with 1LE components?
Alex
2015 Red Rock ZL1
Panama City Beach, FL
nvydvr is offline   Reply With Quote
Old 09-01-2015, 11:40 AM   #11
manganos
Drives: Lexus IS250 and BMW R1200GS
No , v8 only
manganos is offline   Reply With Quote
Old 09-01-2015, 01:02 PM   #12
GMUSA#1
GMUSA#1's Avatar
Drives: 2014 Camaro 2SS/RS 1LE
If I remember correctly, the diff is not the same as the ZL1. I wish that were true. We have standard SS diff.
Peace,
Brent
'14 Camaro 2SS/RS 1LE
'96 Impala SS
'69 Camaro Convertible
GMUSA#1 is offline   Reply With Quote
Old 09-01-2015, 01:23 PM   #13
Shutudwn
You are right about that. My last car was an 03 Cobra. Really hard to beat the low end supercharged torque they make. If you have never experienced that sensation before the Camaro should suffice, but to those that know better well......
Old 09-01-2015, 05:44 PM   #14
Hilflos
Just the components listed for those who want to upgrade their suspension.
Swag1LE gives a more complete list of upgraded componentry that is included in the complete 1LE package.
