Old 09-21-2015, 01:30 PM   #1
Travis104
Drives: 2014 ZL1
Ported LSA vs LS3 throttle body?
Hello,
I had a vmax ported throttle body on my 13ZL1 and traded it in for a 14ZL1 with recaros and a few other options. I was not able to keep the TB since I used the original as a core. I want to do a lower pulley 10% or larger, CAI, headers, tune, and maybe a cam in the future. Which TB would benefit me?
Thanks,
Travis
Travis104 is offline   Reply With Quote
Old 09-21-2015, 02:49 PM   #2
nivek
Drives: 2015 ZL1 Black #100
I am interested in this also.
I know a while back ADM Performance stated that an LS3 throttle body was a great upgrade for our cars. I am planning to purchase one at the same time I do my pulley upgrade.
nivek is offline   Reply With Quote
Old 09-21-2015, 03:04 PM   #3
Travis104
Drives: 2014 ZL1
I couldn't find any data on how much the vmax was ported. I was wondering if it was about a 90mm opening after porting.
Old 09-21-2015, 03:16 PM   #4
winterboy8
winterboy8's Avatar
Drives: 2015 ZL1 Blue Velvet Metallic
I would assume the measurement of the opening is measured at the butterfly. Since this portion of the opening is not ported, I don't think it is a measurement that means anything. The portion of the TB between the butterfly and the intake tube is the portion that is ported and by the looks of the video, I would guess 1-2 mm of material is removed. More importantly it is done on a CNC and is consistent and perfect every time. Good throttle response, no HP gain. I would think if you port the snout, S/C and heads you would really have some good flow and throttle response.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
winterboy8 is offline   Reply With Quote
Old 09-21-2015, 04:18 PM   #5
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Before I went with my Bo White ported LSA TB, I did a little research on it. Apparently, from what I gather, you'll likely need to tune to adjust for the air flow changes using the LS3 TB. If you're tuning anyway, so be it. But it doesn't appear it's strictly a bolt on and go. (And you'll likely need to flip it 180 anyway).
I haven't done it so I cannot verify first hand, but I'm not sure if the stock calibrations can adjust and learn the new TB or a tune would be required.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 09-21-2015, 04:41 PM   #6
Travis104
Drives: 2014 ZL1
I did see where it would have to be inverted. I was curious if the ported LSA would restrict more than the LS3. No plans or porting the snout right now or I would go larger.
Old 09-21-2015, 04:52 PM   #7
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by Travis104 View Post
Hello,
Thanks,
Travis
Hello Travis,
We get to play with this stuff all the time and I can promise you no gain until your at least 125 RWHP over stock then it is actually measurable.
We picked up a couple hundredths of a second at the track in back to back testing at this power level.
At 700 RWHP we picked up 20 RWHP from a Standard LSA to a Ported LS3.
So it is all about Demand vs supply of air, you need to have the demand before you can take advantage of the supply.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 09-21-2015, 05:52 PM   #8
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
LSA 87mm TB & LS3 90mm TB...bigger is better and a direct bolt on. Even unported, it is a cheap mod that is worth a few hp especially with pulley & air intake mods.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 09-21-2015, 06:14 PM   #9
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I only have a few mods...see signature below...and the Vmax TB made things worse...throttle was all over the place after I installed it...like JR said above..unless you 700+ hp don't bother..the stock LSA TB in our cars are fine.....if you have a SS or V6 then it's a must.
Now if you place on tuning then go for it!
Mods:
Old 12-15-2015, 11:20 AM   #10
Travis104
Drives: 2014 ZL1
If I were going to do an 18% lower, headers, CAI, injectors, and tune, would I be ahead to go ahead and do an LS3 throttle body? Or would I be better off to wait until I do more mods to it?
Old 12-15-2015, 11:39 AM   #11
Fraxum
Fraxum's Avatar
Drives: a M6 LT1 ordered From Becky!!!
So while the extra LS3 flow is not significant is there any drive-ability advantages of say a ported LSA TB? Or are they only imaginary on a ZL1?
Having put 2 of them on different LS3s I have to say I am still not sure.
Old 12-15-2015, 01:09 PM   #12
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
I imagine the LS3 gives you a little better throttle response.....
But no real HP or Torq gains until you hit higher HP #'s around 700.
Mods:
Old 12-15-2015, 01:18 PM   #13
Dutchman427
Drives: 2012 ZL1 #1329 M6
I had the stock throttle body ported.
Dutchman427 is offline   Reply With Quote
Old 12-15-2015, 09:53 PM   #14
CanadianZL1#992
ANGRY Z
CanadianZL1#992's Avatar
Drives: 2015 Camaro ZL1
I use unported LS2 silver blade 90mm throttle bodies on my ZL1's.
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
CanadianZL1#992 is offline   Reply With Quote
