Old 10-14-2015, 08:12 PM   #1
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Curing Knock Retard?
Recently I've been running into bad 93 pump gas which gives me some pretty decent KR readings. One tank was up into the 6.0 at WOT area and the last tank was in the 3-4 area at WOT. Got a decent batch of gas currently with KR at 0-.5 at WOT.
So question is, which would be better to boost octane is a bad gas situation...... A can of octane booster (such as Torco) or some sort of race gas added to the tank (such as C10/C16)?
Old 10-15-2015, 09:22 AM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
A can of torco per tank would do the trick.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-15-2015, 09:30 PM   #3
CamaroDreams76
Ted.
thanks for the response Ted.
As far as price goes, Torco 32oz can states it can boost octane rating for 20 gallons 93 octane +4 so 97 octane. Would it be easier and more cost efficient to add an actual race gas, ie. buy race gas in bulk (5/15 gallons) rather than 20 dollars per bottle for Torco.
I have no experience with Torco or race gas so your expertise or a tuners expertise would be greatly appreciated.
Old 10-15-2015, 09:50 PM   #4
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Race gas would cost a lot more to get a mix of 20 gallons of 97 octane than a single bottle of torco
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 10-16-2015, 08:59 AM   #5
JANNETTYRACING
Torco is Race fuel concentrate, you add it to pump fuel according to the ratio chart to obtain the octane you want to achieve.
32 oz raises 20 gallons of fuel 4-5 octane points.
Old 10-16-2015, 09:05 AM   #6
ValZL1
Drives: 2012 Chevrolet Camaro ZL1
Torco is essentially concentrated MMT. It leaves orange haze/deposits (amount dependent on amount of Torco used) on the motor internals. Race gas does not. Mix in 5 gallons of VP MS100 (orange) with a full tank and you'll be around 95 octane for a full tank. More expensive, but no deposits and a nice smell from the exhaust. MS109 if you want a higher net octane. The stoich isnt too far off from E10 pump.
ValZL1 is offline   Reply With Quote
Old 10-16-2015, 09:06 AM   #7
fif_gen_powa
I know you've had good luck on supercharged cars making more power and eliminating knock. Would it have the same benefits on a turbo car? Able to run more boost or more timing and make more power than regular 93?
8.3@164
Old 10-18-2015, 10:58 AM   #8
CamaroDreams76
Thanks for all the responses guys. Appreciate the help.
Old 10-18-2015, 03:41 PM   #9
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Install the complete Elite E2-X Ultra Catch Can system and it will reduce the KR. Log before and after for proof.
Elite Engineering is offline   Reply With Quote
Old 10-18-2015, 06:23 PM   #10
ToddB
Drives: 2011 2SS Convertible Supercharged
Meth injection does wonders and is way cheaper than Torco
ToddB is offline   Reply With Quote
Old 10-19-2015, 02:46 AM   #11
CamaroDreams76
Haven't heard of meth on a NA car.
Old 10-19-2015, 05:21 AM   #12
ToddB
Don't see why it would not help. It raises the overall octane.
Old 10-19-2015, 05:22 AM   #13
ToddB
Old 10-19-2015, 05:24 AM   #14
ToddB
