Old 09-17-2009, 03:11 AM   #1
JoshJ81
JoshJ81's Avatar
Drives: '10 Camaro 2SS/RS Black
Exclamation AFM L99
I asked this in a reply but I think this could be it's own thread and maybe even get a real response from a GM guy without the political BS?
Is the AFM really needed? Why or why not? If not, then why can't we have it tuned out at the dealer and not harm warrenty?
I've seen some people state they can't really see a difference in gas mileage when the AFM is turned off. Thoughts?
I'm taking mine to the dealer on Friday to have the engine and trans computers checked for updates (I hear there is a long list of needed updates). I'm going to make sure to ask about the AFM and if GM has made a reflash to remove the AFM (some said they did, so I'm going to check into it) I'll report back Friday evening if it takes that long LOL.
2SS/RS A6 L99 - Black w/White Stripes
K&N Air Intake System
Muffler Delete
JoshJ81 is offline   Reply With Quote
Old 09-17-2009, 06:05 AM   #2
Augie1978
Augie1978's Avatar
Drives: 2011 2SS RS Vert
I went into my dealership last week to have them order a new clip for my A pilar trim piece that wont stay attached. They ran my VIN number which is 11,526 and told me there were no updates available for my car. I think it would make sense if the AFM would not activate when the car is in sports mode.
2SS RS, Triple Black Vert, Manual, Hurst Shifter. American Racing Headers, Roto-Fab CAI
Augie1978 is offline   Reply With Quote
Old 09-17-2009, 06:18 AM   #3
JoshJ81
JoshJ81's Avatar
11K? Hmm I'm sure I saw someone with a 20k or higher VIN and they gave him a lot of updates? My VIN is 15xxx something.
Muffler Delete
Old 09-17-2009, 03:02 PM   #4
MikeZ28
Drives: '04 GTO, '00 Z28, '95 Z28
If GM used the AFM during the EPA fuel mileage and/or emission tests, it might violate federal law for them to disable it on production cars. I'm speculating, not stating that as a known fact. Plus, the government could see it as GM trying to cheat around the gas-guzzler tax.
MikeZ28 is offline   Reply With Quote
Old 09-17-2009, 03:29 PM   #5
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I'm sure this is true, but the question I think is why couldn't they still warranty it if the customer had it tuned out by someone else.
Old 09-17-2009, 04:28 PM   #6
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
gm does not have the ability to turn off afm/dod, yes there are updates for the ecm, mostly just for misfire counter and a/c clutch protection(shuts off the a/c compressor at a different rpm at wot), and generic scan tool data update
Old 09-17-2009, 04:34 PM   #7
BeermanSS
BeermanSS's Avatar
Drives: 2005 Cobalt SS/SC
yeah GM couldn't do it probably would be considered cheating around the GGTx. They have to prove that the tune (removal of AFM only) is what caused the part or parts to fail. Beyond removing AFM I would say they could prove it, but if you left fueling/spark/airflow/tq mgmt stock they may not. Also would depend on what the warranty claim was on. If it isn't the engine there would be no reason to void the warranty.
BeermanSS is offline   Reply With Quote
Old 09-17-2009, 04:35 PM   #8
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Had mine in for the updates last week hoping to help with the herky jerkys. No help there and it appears my gas mileage has taken a drastic drop. Like from 18mpg to 13 (mix of highway and in town). I'm checking it the old fashioned way since everything was reset after the updates. May still be learning too.
Totally forgot to ask about AFM...
mlee is online now   Reply With Quote
Old 09-17-2009, 05:05 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Wouldn't you have to change the lifters to disable the DOD?
I got to do some research on this since my brother's 2ss will be in soon!
and Im a believer of "SS" meaning Stock Sucks!! LOL
Old 09-17-2009, 05:18 PM   #10
BeermanSS
BeermanSS's Avatar
I don't think so, I think that you would only need to do that if you want to raise the compression and redline up to those of the LS3
Old 09-17-2009, 08:34 PM   #11
iwanttogofastNY
iwanttogofastNY's Avatar
Drives: 2010 Camaro 2SS/RS ABM
what is afm??....sorry tried to find answer on my own
2SS/RS/M6 | ABM | White Stripes | Black Int
Mods: American Racing Headers & Exhaust, Airaid Intake, Pfadt Front/Rear Sway Bars, Stealth Bulbs, AAC LED bowtie, AAC Concept LED Side-markers ABM/Tinted, 20% Tints, Chuck COW Tune, MGW shifter (blue with white racing stripes).
Coming Soon: 4:10 Gears?
iwanttogofastNY is offline   Reply With Quote
Old 09-17-2009, 08:39 PM   #12
JoshJ81
JoshJ81's Avatar
Active Fuel Management, Makes the engine fire on 8 or 4 cylinders depending on your RPM speed to save fuel
Muffler Delete
Old 09-29-2009, 10:52 PM   #13
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Load Based system Saves 5-8% in fuel. If tweaked by a good tuner you can gain up to 20% during highway driving.
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 4.10's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around 24MPG
11.39 @ 118 510 DA
www.6l80tuning.com www.6l90tuning.com
Wacker is offline   Reply With Quote
Old 09-29-2009, 11:18 PM   #14
JoshJ81
JoshJ81's Avatar
Would that void a warranty if made the MPG better?
Muffler Delete
GM High Tech Performance Magazine's L99 Tune - +81 ft lbs at 3500 rpms! SGOS252382 Tuning / Diagnostics -- engine and transmission 52 10-01-2009 12:31 AM
Competition CAMS nearly ready to release their L99 cams for the VVT AND AFM! PatrickfromMD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 32 07-30-2009 06:46 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
installing hot cam logan1080 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 47 11-23-2008 07:12 PM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
