11-21-2015, 01:10 PM | #1 |
Drives: '21 ZLE A10 Join Date: May 2012
1/4 mile runs today...struggles
I ran today a few times trying to get a launch of any sort that didn't induce wheelspin, bog, or wheel hop. It is tough, and I had only 3 runs. I will post my best slip here so you can review. My car is setup 100% for road course and the timing has been reduced accordingly. Of course, 93 octane. The car makes 575rwhp & 500rwtq. Best pass was a 12.45@118.2 with a 2.14 60'. Not great but better before as I could only muster 13.0@110 stock with a 2.10 60'.
11-21-2015, 03:32 PM | #2 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
11-21-2015, 06:01 PM | #3 |
No...it was a good air day at +130ft above sea level. The measured DA was slightly negative. At the time of my best run the DA was -300ft.
11-21-2015, 06:31 PM | #4 |
Treasure Coast Camaro 5
Man u had the drag car and sold it! That BLACK Z looks AWESOME! Money!
11-21-2015, 07:34 PM | #5 |
If I can be on any track, I'm there. The Z/28 is definitely not a drag car...still fun and worthy of a few passes. I just need to practice the launch as this car is very touchy. The burnout became easier after the first two passes.
11-21-2015, 08:51 PM | #6 |
Stephen, go again and this time remove the wicker bill.
11-21-2015, 09:27 PM | #7 |
Drives: Love the one you're with Join Date: Sep 2009
What tires are you running?
11-21-2015, 09:39 PM | #8 |
Drives: 2012 ZL1 #1329 M6 Join Date: Jun 2009
Right on man! I am interested in what tires you were running as well.
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports 784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128 Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms http://www.camaro5.com/forums/showthread.php?t=395950 Rapid Motorsports 396ci Build https://www.camaro5.com/forums/showt...1#post10321301 10.832 @ 130.99 |
11-22-2015, 08:15 AM | #9 |
Yes, the wicker bill was still on the car in the low setting.
11-22-2015, 08:25 AM | #10 |
I ran my ZL1 road race tires which fit the car fine. They are 20x9.5" 30mm offset with tire pressure sensors. The tires are toyo proxes 285/35-20. They work at the track way better than the Pirelli Trofeos. Of course, there is a very slight height difference and the car hated that with ABS, service stabilitrak, service power steering messages after about two mins of driving. After a key off/on cycle the messages reset and I could complete a run without any messages appearing. I ran with the traction control/stabilitrak off. After about a half mile driving home, all of the warning messages reappeared. In my '12 ZL1, these messages would disappear after a little while but they would not in the Z/28.
11-22-2015, 08:27 AM | #11 |
KaBoom1701
Would removing the rear wicker bill upset the aero balance of the car during a drag race?
I know nothing about drag racing so I'm just asking out of curiosity.
Mods:
11-22-2015, 08:40 AM | #12 | |
I dont know, but does the car pull timing or anything when these messages are happening? |
11-22-2015, 09:41 AM | #13 |
Drives: 2023Porsche Cayenne S Join Date: Jul 2010
I went to the strip with and without the wicker bill installed. Both time were slow but I would never make a pass without the wickerbill on my Z again. Just my experience
11-22-2015, 09:46 AM | #14 |
nah...running without the wickerbill would not do anything to the aero balance. The Z/28 already has a more substantial spoiler even without the addition of the wickerbill. For drag racing in the speed range of a Z/28, the less aero drag the better.
