Old 11-29-2015, 09:32 PM   #1
ansibe
Drives: 2015 z28
Heel-and-toe in the z28
Hi guys,
I find the brake and throttle a bit far apart for heel and toe shifting. Has anyone tried a different pedal set? Any suggestions?
Thanks.
ansibe is offline   Reply With Quote
Old 11-29-2015, 10:48 PM   #2
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
Ibe seen a few posts using a similar pedal setup.
http://www.southerncarparts.com/2010...ls-p-2927.html
Zslash28 is offline   Reply With Quote
Old 11-30-2015, 01:20 AM   #3
X25
X25's Avatar
Drives: '16 C7 Z51
Originally Posted by ansibe View Post
Hi guys,
Thanks.
Sit much closer to the pedals and the steering wheel than you normally would at the street. That should make it slightly easier to do the heel and toe, as well as make very sharp turns at the track.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 11-30-2015, 02:30 AM   #4
Bodywerks
Drives: 2015 2SS/RS/1LE
These are exactly what I have been looking for! Thanks.
I'm more of a ball-ball shifter myself(front left ball of foot on brake, right ball on pedal, roll ankle to blip throttle) and these closer pedals are exactly what I have been looking for.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports.
Bodywerks is offline   Reply With Quote
Old 11-30-2015, 09:08 AM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
sullivan racing pedals are very similar and work well.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 11-30-2015, 11:15 AM   #6
FunkedOut
FunkedOut's Avatar
Drives: Black 2010 SS
one in the same.
FunkedOut is offline   Reply With Quote
Old 11-30-2015, 12:26 PM   #7
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
http://www.camaro5.com/forums/showthread.php?t=364019
and seating position plays in as well
"PTM11" Search & Destroy
backtotintops is offline   Reply With Quote
Old 11-30-2015, 05:29 PM   #8
ansibe
Drives: 2015 z28
Sharp turns???? That sounds dangerous!
Old 11-30-2015, 05:37 PM   #9
ansibe
Drives: 2015 z28
Hey, thanks for the video! Awesome to see Senna in action in a road car.
I'm actually pretty good at H-T, but it always helps to have a good pedal set up. It's a low cost mod that can make a huge difference on track. Thanks again for the vid. I'll probably watch it a 100 times and still not be tired of it!
Old 12-12-2015, 04:18 PM   #10
johnr265
johnr265's Avatar
Drives: '15 Z/28
+1 on SRP pedals. Gorgeous pieces, super grippy, and heel toe is a cinch with them on. To properly install, you need to drill the pedals but it is well worth it.
johnr265 is offline   Reply With Quote
Old 12-13-2015, 10:30 AM   #11
JTRATX
Drives: 17 SS 1LE, 14 Yukon Denali
I made my own, one brake, one gas, much needed.
Sent from my iPad using Tapatalk
JTRATX is offline   Reply With Quote
Old 12-13-2015, 10:45 AM   #12
Z28-TX
Drives: 2015 Z-28 / '13 Howe TA2 Camaro
I got this same set and found I still desired a little more mass to the gas pedal. Contacted manufacture and he machined one with an additional .75 - 1 inch mass added to the left side of the pedal.
Connect with Brian at http://www.srpracing.com
Here's pdf of drawing for the pedal he made me.
Z28-TX is offline   Reply With Quote
Old 12-13-2015, 10:59 AM   #13
L99CAMA2011
L99CAMA2011's Avatar
Hi guys,
Thanks.
I find them to be in a good position kind of. Actually I do more of a right side of right shoe toe instead of heel toe since I don't have enough room with my long legs. Works great. Much quicker than heel toe. I move my right foot to the point it is between the break and throttle and press on the throttle and walla.
Old 12-13-2015, 11:21 AM   #14
Stephen12ZL1
Drives: '21 ZLE A10
the "side of the foot" technique works better for me as well. I am not sure how someone gets their heel/toe combo positioned for perfect heel/toe in a Camaro. Their ankle must be much more flexible than mine...weird statement...lol!
