Old 12-25-2015, 09:27 PM   #1
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
Hurst shifter question
Is the hurst short throw shifter better than the stock 1le shifter or are they the same? And do I have to buy the whole shifter assembly or can I just get the chrome stick and shift ball and install it to the stock one?
_Onyx_Wolf_ is offline   Reply With Quote
Old 12-25-2015, 09:31 PM   #2
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Wondering the same thing as far as whether the Hurst is a true upgrade for the GM short throw. Pretty sure if you change, you need to install the entire shifter assembly. GM shifter is a rod, Hurst is a blade.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 12-25-2015, 11:41 PM   #3
cowboy casey
Drives: 2015 Camaro 2SS 1LE
you will need to replace the whole "system" I had the dealer do it...
It makes shifting faster, more direct, LOUDER, you will hear everything your transmission is doing..
Is it better??? It really depends on what your looking for.. I love the Hurst T shifter as that was what was in my original Camaro.
My Daily Driver, 2015 2SS, 1LE
cowboy casey is offline   Reply With Quote
Old 12-26-2015, 01:47 AM   #4
_Onyx_Wolf_
Sweet, how much for the dealer install? The install looks to be a PITA. And are you able to swap different shifter knobs out with this setup? Like if I wanted a pistol grip or something else.
Old 12-26-2015, 03:27 AM   #5
X25
X25's Avatar
Drives: '16 C7 Z51
The OEM 1LE shifter is pretty good. I'm not sure if the Hurst shifter would be an upgrade; it might even be a downgrade. The OEM shifter works pretty good at the track. In my experience, when you get the shifts too short, you start missing shifts every once in a while at the track, since it's a notchy transmission due to its torque capacity to start with.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 12-26-2015, 08:40 AM   #6
cowboy casey
it comes with both "types" of shifter connections.. you can use you're stock shifter, any of the ball knobs, it comes with 1... I used the T shifter but you can use most of the hurst shifter's including the pistol grip...
Warning: The metal shift knob is freakin cold, it is a chunk of metal and can take 4 or 5 minutes to warm up.. I wrapped my T handle in leather and it turned out really nice....
the dealer install was not cheap, it cost me 200 but I did not have the lift or time to do it and it worked for me..
Old 12-26-2015, 11:03 AM   #7
paul84043
paul84043's Avatar
Drives: 2015 Camaro 2SS RS 1LE
Install is really not bad. about an hour and the worst part is getting the rubber boot back over the linkage. If you get your car up high enough, this is a breeze. If not, you'll be contemplating suicide in about 45 minutes.
Other that that spawn of satan boot, the install is very easy.
I'll be installing mine some time this weekend..
paul84043 is offline   Reply With Quote
Old 12-27-2015, 07:55 AM   #8
SSmitch
SSmitch's Avatar
Drives: 14 2SS/RS/1LE
This was my experience installing the Hurst Shifter on my 2014 1LE:
The performance between the shifters is personal preference, the Hurst is "ratchety" and more precise on hard shifting compared to stock, the reason I choose it was the chrome stick and white cue ball (I had that on my 69 Camaro SS when I was younger), otherwise I would have seriously considered a MGW.
I'll share a couple bits of advice; the NVH is increased dramatically so make sure you use the sound deadening material included in the kit, install a bushing upgrade kit (the stock poly bushings do not hold up) & buy another shift boot, (because you have to remove the chrome trim bezel which is glued on and you won't be able to re-use the boot if you want to reinstall the stock shifter) the only handle option with the kit is the chrome handle, it is not compatible with the "stock" ZL1/1LE GM short throw shift knob & shifter handle.
I would say this is an easy project and I did the install and rework on jack stands (lifted front of car only)
6/17/22 UPDATE:
SOLD W/4900 Miles to Berger Chevrolet
Grand Rapids, MI
2014 Camaro 2SS/RS/1LE
Livernois Motorsports:
Ported Heads, TB & Intake.
2 R Max Cam (W/upgraded dual valve springs & pushrods)
Kooks 1 7/8" SS Headers, HF Cats & NPP Exhaust
MSD Wire Set/Roto-Fab CAI
Elite Oil Catch Can/GM Oil Catch Can (Clean Side)
Custom Tune 93 Octane
500 WHP 453 WTQ
Sound Bite:https://www.youtube.com/watch?v=CGBUYF1Ce9Q
Dyno Run:https://www.youtube.com/watch?v=BPE6DrtnVfo
SSmitch is offline   Reply With Quote
Old 12-27-2015, 08:34 AM   #9
Shawno72
Shawno72's Avatar
Drives: 2015 Black 2LT RS M6
So If I want to reuse my 1le shift boot I have to take off the plastic trim ring?
Shawno72 is offline   Reply With Quote
Old 12-27-2015, 10:10 AM   #10
SSmitch
SSmitch's Avatar
That is correct, the Hurst shifter uses a rubber grommet around the shift handle and the top of the boot is zipped tied to it.
The Hurst instructions show the standard Camaro shifter, not the short throw for the ZL1/1LE, FYI.
I referenced this youtube video for the general install...
And these instructions on how to remove the shift knob from the ZL1/1LE short throw shifter....
Name:  shift knob removal 2.JPG
This shows the chrome trim ring is part of the boot VS being zip tied like the standard Camaro shifter...
Hope this helps...
6/17/22 UPDATE:
Grand Rapids, MI
500 WHP 453 WTQ
Old 12-27-2015, 10:22 AM   #11
Shawno72
Shawno72's Avatar
Attachment 763820
Hope this helps...
Yeah that's how my chrome ring is, part of the boot. It attaches to the knob, so wouldn't it just reconnect to the factory knob if I was re-using it?
Old 12-27-2015, 10:32 AM   #12
SSmitch
SSmitch's Avatar
On a standard Camaro shifter yes...NOT ON A ZL1/1LE shifter... the chrome trim ring and shift knob are not the same, the chrome trim ring on the ZL1/1LE shifter is GLUED to the shift boot not zipped tied like the standard Camaro shifter.
6/17/22 UPDATE:
Grand Rapids, MI
500 WHP 453 WTQ
Old 12-27-2015, 10:35 AM   #13
Shawno72
Shawno72's Avatar
On a standard Camaro shifter yes...NOT ON A ZL1/1LE... the chrome trim ring and shift knob are not the same, the chrome trim ring on the ZL1/1LE shifter is GLUED to the shift boot not zipped tied like the standard Camaro shifter.
Ok gotcha. I have a 1le shift boot and knob. It even has the Hurst logo from the factory. Well that kinda sucks, I was hoping it would all fit over the Hurst shift handle
Old 12-27-2015, 10:42 AM   #14
paul84043
paul84043's Avatar
The OEM adapter in my Hurst kit has the slot and tapped mounting hole shown for the ZL-1 / 1LE. The boot connects to the stock shift knob itself so it should all mount back up.
I tried to take a picture of the OEM adapter but it's black on black and I can't get a decent shot of it, it's too hard to see.
