Header Installation Cost
Just ordered a set of Texas Speed Longtubes and called my local shop to find out how much to have them installed They want $550 for the header install I'm just wondering if this is expensive or not ?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
Its about 4 hrs labor
More than $125 an hour shop labor rate? Seems high to me. Ryan
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
![]() Drives: 2013 ZL1 Triple Black Vert M6 #5591 Join Date: May 2013
I usually pay 110.00 per hour, for labor at my shop. Plus not like you bought them there. If you had purchased thru them maybe the labor be cheaper, considering that they would've made so money on the headers. Just my .02. Plus you live in New York, everything in NY cost more...
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice.. |
Chevy's "Rumble" Best!
Drives: 2015 ZL1 6 speed Join Date: Feb 2011
Take it to Ideal Garage in NJ
Keeper of “THE list”
Install them yourself and save $550. I had never installed any myself before I installed mine and while it was challenging at times, it was not impossible for a rookie. Just make sure you torque the bolts to the proper specs otherwise you'll catch all kinds of hell on here. Apparently auto parts stores rent torque wrenches for little to no money. The driver's side isn't too bad and can be done by yourself, but the passenger side is nearly impossible to install solo. The whole process goes a lot easier if you have an extra set of hands.
#6 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
You don't need to torque anything: http://www.camaro5.com/forums/showthread.php?t=402218
Pity a man in familiar places, who yet feels like a stranger.
#7 |
![]() ![]() ![]() Drives: orange 2011 2SS/RS Join Date: Nov 2011
So no one mentioned a tune, header install and no tune ??
ARH 1 7/8" Headers W/HFC, GM Performance Exhaust / K&N Typhoon CAI, Comp Custom Grind Dominator 3 Cam, Pioneer Dual Valve Springs, Trickflow Push rods, IWIS Timing Chain, Rapid Motorsports Tune, 496 RWHP
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
Bring it to PA and I'll only charge you $100. I've installed 3 sets already. I have lift, air tools and torq wrenches.
#9 |
![]() Drives: '16 FiST Join Date: Apr 2012
#10 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 ZL550& 2021 C8 Z51 Join Date: Feb 2010
Ralph is a great guy.
It is not that hard should only take a couple hours. I did mine on the ground with a floor jack and jack stands. It took just over 2 hours including adding CAI at the same time.
#11 |
ZL1 CRT 1 of 53
Drives: 2012 & 2017 ZL1's Join Date: Jul 2010
#12 |
![]() Drives: 2015 Commemorative Edition Join Date: Jul 2013
#13 |
Black Car, this is my lift.
#14 |
+1 on doing it yourself and save the money. Like sscamaro i used air tools. It made a huge difference.
Love the lift! Where did you get it? I need to invest in that! |
| Tags |
| corsa, exhaust, headers, longtubes |
