Old 01-07-2016, 03:47 PM   #1
digdeep0169
digdeep0169's Avatar
Drives: 2012 Camaro SS 45th Anniversary
want: Battery
need a battery for the Gen5 Camaro.
did some price quotes with some of the local guys and I don't want
to spend that kinda $ on batteries I've never even heard of...
what do you got?
~ 2012 SS ~
digdeep0169 is offline   Reply With Quote
Old 01-07-2016, 03:53 PM   #2
myold88
myold88's Avatar
I put a new Interstate battery for my SS last year. $200.00 with tax installed. Not so much
considering 6 years use and it's an excellent battery. How much do you want to spend?
Old 01-07-2016, 03:53 PM   #3
justjoshin
justjoshin's Avatar
Drives: 2010 SW 1SS L99 Camaro
I went to the dealer and replace mine a few months ago.
justjoshin is offline   Reply With Quote
Old 01-07-2016, 04:00 PM   #4
digdeep0169
@myold88 - 6yrs? thats awesome! what is the cold cranking amps? I'd spend $200 for that!
~ 2012 SS ~
Old 01-07-2016, 10:23 PM   #5
myold88
myold88's Avatar
My car was built on 8/4/09 and I replaced the battery last year. It still was
fine but I figured it was on borrowed time. My new Interstate battery is a
MTP 94 R H7. My mechanic said its a direct bolt in vented battery that fits many
GM vehicles and he had it in stock. Cost was $185.99 + $2.99 EPA tax + $12.00
Ct state tax = $200.98 installed. I don't know the cranking amps but I'm sure
you can look it up on the Interstates web site.
Old 01-07-2016, 11:00 PM   #6
GrandAmGT
GrandAmGT's Avatar
Drives: 2010 1LT & 2016 Cadillac CTS V6
When I shopped for batteries last summer, $200 was the prevailing price. You might get lucky and find one for $180. I got a Duralast battery from Autozone. When did batteries become so expensive? Fifteen years ago you could buy a good one for $60.
GrandAmGT is offline   Reply With Quote
Old 01-07-2016, 11:13 PM   #7
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
I run a Braille 15lb (Part # B2015), spent a total of $210 for it off amazon. Had to fab a custom mount (or you could buy Braille's mount kit)... it's not good for anything under 32 degrees (freezing). After 2 years I've only ever had it not start once (was 24 degrees), once it warmed up started no problem.
sealed, will last long past what a vented battery will, and its 35-40lb lighter than stock.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 01-07-2016, 11:51 PM   #8
Blakk11SS
Blakk11SS's Avatar
Drives: 2011 Camaro 2SS/RS
The Interstate MTP 94R H7 ( its named Megatron) is a good option, leave it to a Decepticon to have starting duty - lol. I got one for $178 out the door. Its a big battery but has the CCA you'll need. go for it!
Blakk11SS is offline   Reply With Quote
Old 01-08-2016, 01:28 AM   #9
Ace0751
GEN5 Detail
Ace0751's Avatar
Drives: 2011 Synergy Series 2SS Convertible
I'm also looking into a battery this year, may go with the optima performance. Give it a shot.
Roto-Fab CAI, Borla ATAK Exhaust System, Stainless Power Headers, RX Performance Catch Can, ACS T4 Splitter, Oracle side markers, Dyno Tuned by RDP Motorsports
Ace0751 is offline   Reply With Quote
Old 01-08-2016, 02:28 AM   #10
AF1Strider
AF1Strider's Avatar
Drives: 2011 Camaro 1SS/RS
Let me know what battery and where you get it at. The one in my SS is getting weak as well!
AF1Strider is offline   Reply With Quote
Old 01-08-2016, 09:04 AM   #11
ELIC1
Drives: black and silver
why would someone go cheap on a battery.... never understood why people spend 30 to 40 thousand dollars on a car and treat it like its your baby and then look for a cheap battery.....
ELIC1 is offline   Reply With Quote
Old 01-08-2016, 05:43 PM   #12
BLU DUCE
BLU DUCE's Avatar
Spike III
If you don't mind saying what did your dealer charge for the battery?
Old 01-08-2016, 05:53 PM   #13
BLU DUCE
BLU DUCE's Avatar
I don't understand why people put a sealed battery in the camaro. The battery is in the trunk where it should be a vented battery for heat reasons. It even says in the car manual to put a vented battery in to replace the original. That is why it has a breather tube vented out the bottom of the car.
Old 01-09-2016, 12:02 AM   #14
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
It has nothing to do with heat.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
