Old 02-07-2016, 02:01 PM   #1
Mprjosh24
Drives: Black drop
SS conversion to zl1
Need pulleys and brackets to make the swap
Mprjosh24 is offline   Reply With Quote
Old 02-07-2016, 02:07 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
I took a different track by doing the LSA ADM kit with a lot of ZL1/1LE parts...
ttshovel did the LSA accessories for his SS and may be able to direct you..
Good luck and keep us posted.
-Don
747 RWHP 794 RWTQ
Old 02-07-2016, 06:01 PM   #3
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
What year ss do you have? The 2010-2012s cost more to convert to the zl1 accessory drive. You can't use anything from the stock accessory drive
You need extra-
Ac bracket
Ac compressor
Ac Lines
Condensor
Ctsv power steering pump assembly
Now the cost if you are 2013 and up is roughly 2500 using an ati balancer and bigger crank pulley
2010-12s are 3k and up. Assuming you are buying everything brand new.
ttshovel is offline   Reply With Quote
Old 02-07-2016, 11:46 PM   #4
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
Is the alternator and bracket different as well?
supergt99 is offline   Reply With Quote
Old 02-08-2016, 12:02 AM   #5
ttshovel
ttshovel's Avatar
Yes and yes. And water pump and the supercharger idler setup. The extras I listed above were what's needed over the 2013s and up. Or you could just buy the adm 8 rib conversion as they use all your stock accessories
If you find my build thread it's all in there or I could make a diy with part numbers
Old 02-09-2016, 09:51 AM   #6
ADM PERFORMANCE
Drives: Anything I want
You need extra-
Ac bracket
Ac compressor
Ac Lines
Condensor
This is why our setups are such a great deal for the money.
ADM PERFORMANCE is offline   Reply With Quote
Old 02-09-2016, 03:40 PM   #7
ttshovel
ttshovel's Avatar
Couldn't agree more! You still Need to buy a balancer, crank pulley, and a pin kit. So there is an extra $750
It's definitely not a cheap upgrade at all
