Old 02-13-2016, 09:11 PM   #1
Hunker
Drives: 2014 Camaro 2ss
Oil pump
So I am doing a head and cam mod , I keep reading a lot about oil pump replacement. My question is do I need to change my oil pump also?
Hunker is offline   Reply With Quote
Old 02-13-2016, 09:43 PM   #2
SrtWtF
SrtWtF's Avatar
Drives: Nsrt & Camaro SS
Miles? And l99? or ls3 manual?
SrtWtF is offline   Reply With Quote
Old 02-13-2016, 10:46 PM   #3
Hunker
7000 miles and ls3 6m
Old 02-14-2016, 02:22 AM   #4
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
Most of the info I came across while investigating this due to my oil pump failure were from older (2010) Camaros. I'd change it out for peace of mind and make sure you use the proper oil for your setup when doing cam.
Some good background reading:
https://www.google.com/search?q=2010...sm=93&ie=UTF-8
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 02-14-2016, 09:08 AM   #5
christianchevell
old school chevy rodder
christianchevell's Avatar
you want higher volume which results in higher pressure readings..... some stock pumps had a tendency for sticking parts, and BTW make sure the O ring for the pump is right and on there and not left behind in the old pump from the pick up tube that keeps the pick up sealed tight and the thing is not laying on the bottom of the pan...read about these problems on here before..... While it is not really needed to change out the chain and pump it is advisable as the ls3 tensioner can get brittle and break compared to the ls2 dogbone , and higher volume means better lube to parts. And a C5R chain is the norm as single roller chains don't stretch they do wear on the roller though... chains don't stretch the teeth of the gears dig into the roller part of the link over time and bad harmonics from being built can vibrate the chain more.. along with bearings etc... and a good harmonic balancer is good for that also, yet the dampener with our internally balanced engine does get reused by most and they do not think about down the road ...kind of like breaking in the roller cam....... because a roller cam does not instantly eat its self to death like a flat tappet cam with low ZDDP oil etc....and only costs like four times more about the same as the engine SBC 350 versus ls3......
And yes I do a BR30 driven racing oil break in...... but hey do what you will, its entertaining over time learning through the years of others failures to even simply use racing oil or do a break in because they know it all.... Yes I am a old motor head who built things repeatedly myself.... Mostly Chevies...
Old 02-14-2016, 10:09 AM   #6
hesster
hesster's Avatar
Drives: '10 T/A Conv, '10 2SS, '77 SE T/A
My tuner was adamant on not replacing the oil pump when installing my Whipple and Blower Cam. Most failures were attributed to the relief valve sticking, and contamination, both some factory machining debris issues and or not maintaining oil changes. He did replace the timing chain, sprocket, and did away with the spring loaded tensioner, and went with the dog bone design.
hesster is offline   Reply With Quote
Old 02-14-2016, 04:28 PM   #7
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Since you have the LS3 I would definitely change it out for a melling hv.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 02-14-2016, 05:47 PM   #8
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
The issue with some factory pumps is a sticking relief. You can clean up the piston and bore with a light emery cloth or you can choose to move to an aftermarket pump like the Melling. I'd ask what you are using the car for? If it's just a daily feel free to reuse the factory pump and do the clean up. I've run a couple Melling 10296 pumps with great success. One straight out of the box and one that I did a bunch of port work to.
Bottom line, you are going to get a million opinions on this topic. You'll have to decide which one you want to follow. Good luck.
Travis
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
Old 02-14-2016, 06:37 PM   #9
Russell James
Russell James's Avatar
I nice strong magnetic drain plug, and a filter magnet are cheap insurance to try to keep debris to a min.
It's the debris that is a prob sticking that relief valve. It can also be perfected as mentioned.
Also make sure the oil pump is centered when installing. If the installer has never heard of centering the pump, be very concerned.
If it were me, and I had all that apart... I'd put a melling HV in there. Especially if you are adding stiffer valve springs. Your lifters and oil and oil pressure were all spec'd out for the stock valve springs. Stiffer springs... one might like a little more oil pressure to support the lifters and try to avoid some ticking.
Old 02-14-2016, 06:57 PM   #10
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Just do it and not worry about it.
Trob85 is offline   Reply With Quote
Old 02-14-2016, 08:21 PM   #11
Soybeanrice
Soybeanrice's Avatar
Drives: 2014 2SS/RS
its so, so, so, so, so, so easy to recommend spending more money. Remember that.
Answer: No. Recommend? Yes
Soybeanrice is offline   Reply With Quote
Old 02-14-2016, 08:24 PM   #12
Hunker
I guess my follow up question should be is this still a problem with ls3 engines built after 2010, I haven't seen or heard many people with newer engines having this problem.
Old 02-14-2016, 08:25 PM   #13
Soybeanrice
Drives: 2014 2SS/RS
I thought I read something about the valve sticking being related to 2010/2011, someone would have to clarify that.
Old 02-14-2016, 08:40 PM   #14
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
The stock pressure and volume fine. At leased have the stock one ported or go with a melling 10295 is fine the 10296 is for engines clearensed for a hi volume pump. Both will work fine just not needed. Both pumps come with a high pressure spring installed and a regular pressure in the box. There's no wrong answer with any way you set it up.
JCunningham is offline   Reply With Quote
