Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 02-25-2016, 11:38 PM   #1
UNDRFTD
Banned
Drives: Deep Matte Black 2015 2SS1LE
Anyone Running Rear 325 or 335/35/20
Anyone Running Rear 325 or 335/35/20 Post Pics Please!
UNDRFTD is offline
Old 02-28-2016, 05:24 PM   #2
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
It takes a perfect offset for anything over 315's and you may still get some rubbing during corners or bumps. It wouldn't take a lot to clearance enough room at the upper wheel tub and then you could go all the way to 345's.
2013 A6 ZL1
Redlineviper is offline
Old 02-28-2016, 05:26 PM   #3
UNDRFTD
Banned
No such thing as a Perfect Offset, it all depends on the use of your offset.
I'm planning on running 285/35/20 Fronts & 315/30/20 Rears on ZL1.
UNDRFTD is offline
Old 02-28-2016, 08:31 PM   #4
SSmokey
Drives: 2012 Black ZL1 Camaro
I have a 2012 ZL1, I currently have Michelin Pilot Sport PS2 on the car 335 out back I have had no issues with rubbing or hitting the fender. They are mounted on factory wheels.
SSmokey is offline
Old 02-28-2016, 08:37 PM   #5
UNDRFTD
Banned
Finally someone w| sense... Got Pics!?
UNDRFTD is offline
Old 02-28-2016, 08:39 PM   #6
Redlineviper
Drives: 2013 ZL1
There is when you move up to a 12" wheel which technically is ideal for tires over 315. Then you need to move inward about 3/4" out out 1/4. Otherwise it will stick out too far or rub on the inner tub.
2013 A6 ZL1
Old 02-28-2016, 08:40 PM   #7
UNDRFTD
Banned
Stick Out: some guys like that so its not an issue....
Rub Fenders: doubt it, you'd have to be Lowered enough.
UNDRFTD is offline
Old 02-29-2016, 12:18 PM   #8
Ben69
Ben69's Avatar
Drives: 2013 VR ZL1
http://postimg.org/image/3rkrtkw6r/
325 40 18
2013 ZL1 Victory Red - 628
2015 Chevy Silverado Midnight Ed. 6.2 1500 LTZ Z71
Ben69 is offline
Old 02-29-2016, 12:53 PM   #9
UNDRFTD
Banned
Originally Posted by Ben69 View Post
Need to see from All Angles man. Rear matters most so can see how much it sticks out.
UNDRFTD is offline
Old 02-29-2016, 04:16 PM   #10
Ben69
Ben69's Avatar
Drives: 2013 VR ZL1
Ill get you the picture later today, I have the car at home.
Ben69 is offline
Old 02-29-2016, 06:25 PM   #11
Redlineviper
Drives: 2013 ZL1
I believe 325/40/18's are not as wide as 325/30/20's, can anyone confirm?
2013 A6 ZL1
Old 03-01-2016, 07:34 AM   #12
Icemanmanf
Drives: 2013 Camaro ZL1
According to this tire size calculator, the width is the same
https://www.tacomaworld.com/tirecalc...0r18-325-30r20
Icemanmanf is offline
Old 03-01-2016, 01:27 PM   #13
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
Those are 325/45/18
Id like to see more pictures too, because i plan on going with that exact set up
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline
Old 03-01-2016, 01:41 PM   #14
UNDRFTD
Banned
Looking forward to it!
UNDRFTD is offline
