Old 03-02-2016, 12:15 AM   #1
SantosNL
Drives: 2012 Camaro 2SS
Centri blower + gears + stall
I was wondering if anyone could give me some I put on a f1-a Procharger and let's say 3.70 gears with a 3600 multi disk stall? I've heard that centri's like gear just wanting to get some info on a new set up
SantosNL is offline   Reply With Quote
Old 03-02-2016, 09:19 AM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
I have a centri, 3.73 and a 3600 but its not together yet. Ill let u know in a few weeks
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 03-02-2016, 09:55 AM   #3
pancherj
Drives: 2010 Camaro SS
I have the Novi1500, 3.89 gears and a 3600 stall. I haven't been to the track yet, but I am sure this setup is a compromise. For best track times, it probably would want even more gear and converter (just based on the dyno graphs).
pancherj is offline   Reply With Quote
Old 03-02-2016, 10:13 AM   #4
SantosNL
How much power are you making can you post a picture of your Dyno graph
Old 03-02-2016, 10:23 AM   #5
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Centri's love high stalls, keeps the RPM'S and boost up. Even though I have a baby V6, my Circle D stalls it to 5200 and never falls below 10 PSI (16 @ redline).
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 03-02-2016, 11:52 AM   #6
pancherj
Dyno Graph
This is the graph without the restrictor in place and also when the car was still a stick shift. The ultimate power doesn't matter though...its the shape of the curve. Looking at this, optimal would be something that stalls around 4500RPM (near the torque plateau) and I'd want to shift at around 7100RPM since it peaks at 6800rpm.
Old 03-02-2016, 08:12 PM   #7
SantosNL
What does a restrictor plate do?
Old 03-02-2016, 08:48 PM   #8
D3R3K
Sittin side ways
D3R3K's Avatar
Drives: 2010 2SS/RS IOM
F1-A ftw!
850+hp club member
Procharger F1-A
D3R3K is offline   Reply With Quote
Old 03-02-2016, 09:44 PM   #9
pancherj
Limits the max boost. With the restrictor, I hit 12psi and without it I will top out at 16psi.
Old 03-02-2016, 09:56 PM   #10
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
I have a 6 speed I did 3.23 gears and love it
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
Old 03-03-2016, 11:09 AM   #11
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Wish I could hit 16lbs with the F1A on my 427 all the calculators have shown me between 12-13lbs
Bildo is offline   Reply With Quote
Old 03-03-2016, 12:28 PM   #12
pancherj
A 427 sounds like a lot of engine to feed with an F1A. But...boost is just a number. Does it make good power and carry the curve for a long RPM band?
Old 03-03-2016, 01:06 PM   #13
Bildo
Bildo's Avatar
No clue still can't afford injectors and a clutch yet after buying heads, ERL shortblock, E-85 conversion and squash dual setup and F1-A tuner kit..... hoping to break 800rwhp and expecting 12-13 lbs on the low compression (9.5:1) motor.
Figure I will drive it for a season or two then swap out the head unit to a F1X and aim for around 18lbs after I sure up the driveline.
Old 03-03-2016, 03:29 PM   #14
pancherj
I don't know how the flow curves look when comparing the F1A to an F1X. It may be that the F1A hits harder down low and you may like that more. I debated switching to a YSI with mine, but limiting the boos to hold it under 850RWHP. Matt at FSP said I would lose torque down low and I would regret the decision. If you are going all out...bigger is always better! LOL
