Old 09-25-2009, 11:47 AM   #1
rasby
rasby's Avatar
Drives: Black 1SS
Smile Diffrent Offset
I wanted know if changing the offset from 20x9 +40mm to 20x10+35mm would have any major difference? Also would this be something that can potentially void the warranty. Thanks in advance.
rasby is offline   Reply With Quote
Old 09-25-2009, 03:23 PM   #2
CGM2SSRS
susp.ban4life!
CGM2SSRS's Avatar
Drives: Raptor
My take on this is, depending on what tire size and suspension mods you do up front could have an issue with a 10"x20".
There is a lot of testing on wheel and tire sizes as well as offsets happening right now. 35mm on the rear also is questionable without knowing what your intentions are on everything else.
Just going with a 305x20 you should have no problems with a 35mm offset, and it will not void your warranty.
CGM2SSRS is offline   Reply With Quote
Old 09-25-2009, 03:30 PM   #3
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
As CGM2SSRS stated, as long as your not lowering your car, since you are putting a 1" wider wheel on the back, and only moving the offset in about a 1/4", you would be just fine, no problems at all.
Old 09-25-2009, 05:16 PM   #4
rasby
rasby's Avatar
Drives: Black 1SS
Thanks for the responses!!
offset henri26900 Wheels and Tires Talk Sponsored by The Tire Rack 4 08-09-2009 11:36 AM
Stock Offset???? BumbleBeeSS2009 Wheels and Tires Talk Sponsored by The Tire Rack 1 06-14-2009 10:40 PM
Aftermarket wheel compatibility CamaroSkooter Wheels and Tires Talk Sponsored by The Tire Rack 19 04-03-2009 06:41 PM
Wheel offset of stock wheels? jc211 Wheels and Tires Talk Sponsored by The Tire Rack 0 03-27-2009 02:54 PM
Offset and lug pattern of CAMARO 5 x4.75? D1BADZ Wheels and Tires Talk Sponsored by The Tire Rack 27 12-02-2008 01:24 PM
