Old 03-19-2016, 04:53 AM   #1
95cisneros
Drives: 2014 Camaro
2014 camaro v6 suspension packages
Do v8 suspension fit the v6? And who knows some good suspension packages for the v6?
95cisneros is offline   Reply With Quote
Old 03-19-2016, 07:05 AM   #2
Shawno72
Shawno72's Avatar
Drives: 2015 Black 2LT RS M6
Yes the v8 fits. If your not going aftermarket and wanna stay GM then go straight for the 1le upgrade kit. Best bang for your buck.
http://www.superchevy.com/features/s...ro-suspension/
http://www.shopchevyparts.com/perfor...-92279717.html
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
Shawno72 is offline   Reply With Quote
Old 03-19-2016, 01:20 PM   #3
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Eddiefuzz is offline   Reply With Quote
Old 03-19-2016, 05:03 PM   #4
boss281
Drives: 2015 Camaro RS V6
That's an amazing price, but at the shopchevyparts.com link, it says this handling kit requires an SS Brake Kit! That's $5k! What am I missing???
boss281 is offline   Reply With Quote
Old 03-19-2016, 06:46 PM   #5
Shawno72
Shawno72's Avatar
No there are plenty of used kits for sale here on the forum. Look here
http://www.camaro5.com/forums/forumdisplay.php?f=105
Old 03-19-2016, 08:33 PM   #6
derek1387
Drives: 2015 1LS Red V6
Yup, get the Brembo's as a take off from someone elses project. I have less than $400 in my whole brembo package
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 03-19-2016, 09:41 PM   #7
boss281
I'm curious, is it a clearance problem? Is this something that can be solved without trying to track down an inexpensive take off?
Old 03-19-2016, 09:41 PM   #8
derek1387
It is a clearance issue yes
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 03-19-2016, 11:12 PM   #9
Shawno72
Shawno72's Avatar
The rear 1le and any other v8 sway bar will not clear the stock v6 rear brake calipers.
Old 03-20-2016, 01:09 AM   #10
boss281
Ah, so if I can't find the entire kit at a reasonable price, just the rears will do? that's good to know...
Old 03-20-2016, 07:58 AM   #11
JMT
JMT's Avatar
Drives: 2013 1LT
Almost correct, if you have the 18" wheels they will no longer fit with the brembo brakes.
JMT is offline   Reply With Quote
Old 03-20-2016, 08:28 AM   #12
boss281
The car came off the lot with 20s so we are good...
sent from my cell phone...
Old 03-20-2016, 10:53 AM   #13
Shawno72
Shawno72's Avatar
I also just upgraded to the SS master cylinder for a more firmer pedal. Not absolutely necessary but well worth it. Here are some pics of the upgrade from my car. Also make sure you get the SS front brake hoses. Mine came with the calipers and pads which I got for $425 shipped. The rotors I got off cl locally for $200 new
Old 03-20-2016, 11:02 AM   #14
derek1387
Looks great
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
