Old 09-26-2009, 01:50 PM   #1
newgenss
http://gtoautoglass.com
Drives: 2010 Camaro RS SS
Wheel spacers?
Has anyone made wheel spacers for the SS model? I want to keep the factory 20's but want a "flush" fit where the wheel is aligned with the fender. The back would not be much more to get flush but the front would need a bigger wheel spacer.
newgenss is offline   Reply With Quote
Old 09-26-2009, 02:48 PM   #2
redjewel
Drives: 2010 Camaro 2SS RJT
Not a good idea. Wheels spacers are not good. They take away how much far the lug nuts catch on the stud. If you really want flush look for aftermarket with a lower offset to do it correctly. Good Luck
2SS RJT A6 Sunroof Polished Wheels. Delivered 5-22-09 by Classic Chevrolet Sugarland
redjewel is offline   Reply With Quote
Old 09-26-2009, 05:04 PM   #3
newgenss
I had them on my previous ride they actually bolt up like a wheel and the spacer itself has studs, they are called hubcentric spacers. heres the link http://www.ichibausa.com/whspveii.html
Old 09-26-2009, 06:41 PM   #4
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
well I agree with redjewel, WHEEL SPACERS ARE A BAD THING. I have been hotrodding a LONG time, IF you want different wheels on your camaro, buy them with the correct offset, otherwise, pass on them. Buy wheels that fit properly.
Old 09-26-2009, 06:48 PM   #5
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
If you want this style and are NOT running drag radials/slicks, Eibach makes these. I do not know if they have made the 5x120 yet. They do make a 5x4.75. May want to call them to see.
Old 09-26-2009, 08:33 PM   #6
newgenss
The problem is I actually like the factory wheels. I have yet to see any other wheel that "FITS" the cars style( my opinon). I will consider your suggestion when factory style wheels are available in different offsets
Old 09-27-2009, 01:27 PM   #7
75rusty
awesome!
Drives: 07 Jetta WB, '92 GTI 16vT, '76 LUV
The H&R DRA series spacers bolt on using your studs and provide new studs to attach your wheels.
This would be fine in my opinion if you are NOT drag racing the car or using slicks, I see no issues on a street car.
For instance, Porsche's use them all the time on the Turbo cars, and they make more power than a stock SS Camaro.
75rusty is offline   Reply With Quote
Old 09-27-2009, 04:53 PM   #8
speedster
SST...
speedster's Avatar
If you really want to stick with the factory wheels call Weldcraft. They can widen and change your wheels anyway you like.
http://www.weldcraftwheels.com/index-1.html
Old 09-27-2009, 05:14 PM   #9
Palerider
Palerider's Avatar
Drives: 2 Bullitts = 1 Factory, 1 Reload
Contact these people. I have their spacers on my modded 420HP Bullitt Mustang. They will know where to steer you. http://www.mustangwheelspacers.com/
Palerider is offline   Reply With Quote
Old 09-27-2009, 11:03 PM   #10
newgenss
Wow never even know that was possible. I might go this route since the cosensus is WHEEL SPACERS ARE BAD.
Old 09-28-2009, 01:21 AM   #11
DTM
DTMphotography
DTM's Avatar
Drives: 10' Camaro SS
thats amazing!
2010 2SS/RS: 12.77 @ 111mph (muffler delete) - SOLD
DTM is offline   Reply With Quote
Old 12-25-2009, 01:41 PM   #12
JDBeck23
Drives: 2010 Camaro, 2SS/RS
I disagree completely. If you spend the money on a quality wheel spacer, like Eibach or H&R and install them properly, you have nothing to worry about in a street application.
Drag racing with slicks is a whole different story.
I have run H&R 25mm spacers on previous cars without a problem. The higher quality wheel spacers are also hubcentric, made specifically for that car's hub diameter. If you buy the right spacer, there is no downside unless you plan on racing.
2010 2SS/RS CGM
American Racing Headers, Magnaflow axle back, Roto-Fab CAI, Audio Integrations Sub box, Alpine Type R 10, Alpine MRP-500 amp, Pro Clips iPhone Mount
JDBeck23 is offline   Reply With Quote
Old 04-12-2011, 01:32 PM   #13
bjorno
Drives: 2010 camaro 2ss rs 6m
Here's what I did to close the fender/wheel gap at the front. I purchased a pair of rear OEM rims on EBay and put them on the front with the stock 245 tires. It made a noticeable difference and now in balance with the rear. If you think you need more buy a set of OEReplica wheels 9" all the way around. The difference is the 35mm offset vs. 40mm of the stock rims which brings the wheel out another 1/5" on top of the 3/10" gained using the 9" OEM rear rims. Small numbers, big difference.
bjorno is offline   Reply With Quote
Old 05-23-2011, 06:49 PM   #14
CooG
RIP - Convertible SS
CooG's Avatar
Drives: '13 Mustang Boss 302 - RED
Yep - GOOD wheel spacers made of billet aluminum and using a CNC machine are fine. NEVER buy cast aluminum wheel spacers. They will eventually crack and fall apart. Most billet aluminum spacers are $150-200 a pair. Cast spacers are well below that.
CooG is offline   Reply With Quote
2SS Silver Ice Metallic at ATL Car SHow Cmurf_SS Camaro Photos | Spyshots | Video | Media Gallery 40 11-09-2009 10:38 PM
SS with wheel spacers and 18" steelies for winter WickedRamAirWS6 Wheels and Tires Talk Sponsored by The Tire Rack 2 09-24-2009 04:55 PM
Steering wheel leather cracking!! meliss7567 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-17-2009 03:13 PM
Anyone install wheel spacers ? Santos Wheels and Tires Talk Sponsored by The Tire Rack 4 09-16-2009 09:18 PM
**New ForgeLine DE3P Wheel Design Release!!** Anthony @ LG Motorsports Wheels and Tires Talk Sponsored by The Tire Rack 51 08-17-2009 09:10 PM
