![]() Drives: trans am Join Date: Jul 2006
MUFFLER DELETE
I've read that some of you guys have installed a Tru-X-pipe with a muffler delete. Is this a package from after market exhaust companies that delete the muffler? I've heard the one on the guys commercial and it sounds great. Any info would be appreciated.
![]() Drives: 2010 2SS/Black Join Date: Mar 2009
You can get the muffler removed and replaced with a straight pipe at a muffler shop. Cheaper than a pre-made muffler delete. The x pipe can be bought aftermarket.
2010 Black 2SS L99
Mods: * CAI Intake * Magnuson MP2300 TVS Supercharger/RDS Spacer * Vector Motorsports Tune * Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series * R1 Concepts ceramic pads and slotted/drilled rotors |
Thanks. Have you heard one that this was done on? Does it sound that good? My concern is a drone at highway speed. Would that be the case with this setup?
![]() ![]() ![]() Drives: '10 Camaro SS Join Date: Apr 2009
The ones that i have heard sound pretty good, but you will have ALLOT louder popping sound off throttle coasting.
2010, SIM, 2SS/RS, LS3, CGM Stripes
![]() Drives: 2010 VR 2SS A6 Join Date: Jul 2009
I think the throttle popping all depends on how they run the pipes, I had my mufflers cut off and I have hardly any popping at all. I absolutely love the sound of the delete and so glad it only cost 80$ to do it.
#6 | |
I can bolt the stock mufflers back on where the SLP LM II bolts on. If you get a muffler delete, have them use a sizsaw to cut off the stock mufflers and use clamps to join the two half's. I cut the exhaust pipe about 1.75 inches from the muffler(s) on the engine side. Hope this helps.
2010 Black 2SS L99
#7 |
I did the muffler delete. I like the sound. A little drone, but it is tolerable after you get used to it. It is mostly noticeable if you are driving without the radio on.
#8 | |
![]() Drives: 2010 Camaro 2SS RS M6 Join Date: Aug 2009
I did the muffler delete and added a magnaflow tru-x pipe. I think it sounds great. It is definitely louder than stock, but not obnoxious. I commute 100 miles a day, and at cruising speeds the exhaust is barely audible. Also, I have not noticed any drone. However, there is increased popping on decel, but I think that is generally the case with the majority of aftermarket systems on these cars.
I highly recommend this setup if you want a great sounding exhaust at a very affordable price.I purchased the x-pipe from summit for around $90.00, and had my local exhaust shop weld everything up for another $150.00. Here is a video of BLACK10's car with the exact same exhaust as mine. His exhaust is what sold me on this set up...
2010 Camaro 2SS/RS M6 Black on Black
22" Vossen CV1 Wheels, Roto-Fab CAI, Dynatech 1 7/8" Long Tubes w/ High Flow Cats, Magnaflow Tru-X Pipe, Barton Short Throw Shifter, Vector Motorsports Tune, Ground Effects, MPD1 Spoiler |
#9 | ||
![]() Drives: IBM 2010 Camaro Join Date: Dec 2008
2SS/M6 | Imperial Blue Metallic | White Stripes | Black Int
#10 |
![]() Drives: BLACK/BLACK 2SS RS GFX Join Date: Apr 2009
Would a muffler delete and full ARH setup be over kill? Would that be toooo loud?
#11 | |
#12 |
I think if you had the off road version without cats then it would be very loud. I plan on getting long tubes with high flow cats. If it is too loud, I will either have some mufflers welded or just buy an axle back system.
#13 | |
#14 |
Thank you all for the info. It was very helpful.
| Video of my L99 with DT shorties and muffler delete | thebrainhart | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 9 | 09-21-2009 01:06 PM |
| Considering a Muffler Delete, Straight Pipes or NOS in Ontario? | Matster | Canada | 18 | 08-29-2009 04:41 PM |
| Muffler Delete with Dyno clips and pictures | KK2010SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 9 | 07-26-2009 03:09 PM |
| Muffler Delete = less power? is it even possible? | LDGn63 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 06-29-2009 10:47 AM |
| To muffler delete or not to delete | BumbleBeeSS2009 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 81 | 06-25-2009 05:55 AM |
