Old 03-22-2016, 12:13 PM   #1
Mrpaintballordie
Drives: 2018 SS 1LE
Having doubts. Need advice.
Hello everyone. I've had my 15' 1le for about 5ish or so months. I just bought a set of kooks header, CAI, and 160 degree thermostat. But my parents aren't really happy about it they called the guy who sold me the car and told them that it will void the warranty. And I'm only at around 5800ish miles. Should I just put them on anyway? I've gotten a lot better at manual but I am still no expert. Sometimes I will miss shift.
Do you think I should put them on and void the warranty and risk it. Or just sell them and put the intake on and wait? Thanks in advance.
Ps this is my car I pay for everything I'm not some spoiled kid
Mrpaintballordie is offline   Reply With Quote
Old 03-22-2016, 12:23 PM   #2
arkentect
arkentect's Avatar
Drives: 2010 Camaro SGM 1LT M6
You gotta pay to play my friend. My 2010 LLT just got a new motor put in last year which came with a 3yr warranty so naturally I'll wait a little bit till I mod the motor. With the LS3 being a much more reliable motor I would feel less nervous doing anything to it than I would my current LLT.
In reality its your car and nobody can tell you what to do. I would definitely get the hang of the manual before you go adding more power though. Nothing like having 450hp and not knowing how to handle it.
Arkentect's Build Thread!! - UPSTATE C5 MEMBER
2010 SGM M6 1LT - SOLD
Current - 2009 C6 Corvette Z51
arkentect is offline   Reply With Quote
Old 03-22-2016, 12:47 PM   #3
jeff657756
Drives: 2014 SS 1LE
Why would your parents call the guy who sold it you if they didn't buy it? Sounds like its their money in some form or another so you might want to listen to them.
jeff657756 is offline   Reply With Quote
Old 03-22-2016, 12:48 PM   #4
DILLIGAF
DILLIGAF's Avatar
Drives: 2023 ZL1 M6 Rapid Blue
I'm willing to buy the headers (if you have the high flow cats too) from you if you decide against installing them. I just bought an intake and tuner and was going to wait on headers but i can help ya out.
2023 Rapid Blue ZL1 M6
| Corsa NPP | Corsa Carbon Fiber Intake | Hardwired Valentine1 Gen 2 | Pro Clip Phone Mount |
DILLIGAF is offline   Reply With Quote
Old 03-22-2016, 01:46 PM   #5
Mrpaintballordie
Drives: 2018 SS 1LE
Because the guy who sold me the car is a buddy of my dads and they talk from time to time I guess he saw the package and decided to ask
Old 03-22-2016, 02:04 PM   #6
arkentect
arkentect's Avatar
Luckily! Its not your parents car. Do what you want. If you're worried about breaking the car you shouldn't be modding then. Pay to Play. Cut the umbilical cord.
Old 03-22-2016, 02:06 PM   #7
arkentect
arkentect's Avatar
If you dont want to use the headers the guy in the link below is looking to buy some.
http://www.camaro5.com/forums/showthread.php?t=445326
Old 03-22-2016, 02:16 PM   #8
maraging
Drives: 15 1ss 1le
Headers and a cai dont automatically void your warranty.
maraging is offline   Reply With Quote
Old 03-22-2016, 02:34 PM   #9
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
No, but he will likely get a CEL and need a tune, which most dealers will use to void your warranty.
Thor142 is offline   Reply With Quote
Old 03-22-2016, 02:43 PM   #10
jeff657756
Drives: 2014 SS 1LE
Well then go ahead and do what you want. We would all be lying if we said we weren't a little worried when we did that first mod that voided the warranty. After that, you will just want more. Enjoy it.
Old 03-22-2016, 03:38 PM   #11
markgws6
markgws6's Avatar
Drives: 2019 Chevy Equinox Premier AWD
I had a V6 Gen 5 and when I installed JBA "shorty" headers that were CARB approved, they caused an exhaust related CEL (check engine light) after some time, like 2 months. I knew not to take it to the dealer, since the car was still under warranty. I drove my car that way until I tried to have a local performance shop fix it. I had the header collectors welded (they were held on by a clamp) to the exhaust pipe and it still got the CEL. I then bought a $700 tune and was told by the tuner that they would tune out the CEL. Guess what? It came back again after some time. I'm not trying to scare you or anything. Plenty of people on here have had good experiences with installing headers on the LS3. It's your car so it's your decision. Most of all, enjoy it!!
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43)
markgws6 is offline   Reply With Quote
Old 03-22-2016, 05:33 PM   #12
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Installing headers on a 5th gen is as easy and simple as it gets ,you should be able to do it yourself. CIA also easy .You do not need a 160 T stat ,stick with the factory T stat. If you get a CEL ,and you most likely will , get a tune and enjoy.
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 03-22-2016, 06:11 PM   #13
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
If the cause of the failure was related to the aftermarket work/parts done, and installed on the car. Than the warranty is VOID. If you install headers and do a tune, and your right front wheel bearing goes out at 7k miles. You still have a warranty and they can not deny the repair. UNLESS they can some how attribute that to the mod.n That is not my opinion, that is the law. It's called The Magnuson-Moss Act
Are you an adult? If not, then listen to your parents and be a good boy. If you are, then act like one, and make your own decisions.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-22-2016, 06:46 PM   #14
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
If your warranty is voided due to the tune you'll have to get, and your car requires engine repair, will you be able to pay? If mom and dad have to pay so you don't take the bus, then don't do it. If you're ok paying a few grand without destroying every other aspect of your life, go for it. I was 18 and had a 3rd gen z28. Put a ton into it then totaled it. Not disrespecting you but your young brain, as smart as you are now, will see life totally differently than your more life experienced brain 20 years from now.
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
