Old 03-25-2016, 11:28 AM   #1
domano 68
domano 68's Avatar
Drives: 2014 1LE
Inside the Dual Mode Exhaust Muffler
Looking for an inside view of a dual mode exhaust muffler. I want to see what actually is going on when either mode occurs. Wondering if anyone has actually cut these open to see. No luck finding a picture or video yet. Thanks in advance.
domano 68 is offline   Reply With Quote
Old 03-25-2016, 03:28 PM   #2
Chris1SS1LE
Chris1SS1LE's Avatar
Drives: 2014 Camaro Red Hot 1LE NPP Recaro
Saw a pic drawing of one, Basically it comes in and has two routes one goes straight with tiny holes perforated and out to the valve. The other tube Y's off and goes at angle thru fiberglass to the other exit point just like a normal muffler. When the valve is open your straightpipe except the perforated holes and possible some chambered crimps. If you didn't do a NPP you could always put cutouts before the muffler and dump straight down and get the same effect, but much louder. A friend with his mustang does this and the cutouts only open at WOT.
Chris1SS1LE is offline   Reply With Quote
Old 03-25-2016, 04:30 PM   #3
hcsi99
Cadillac Service Manager
hcsi99's Avatar
Drives: 2014 Camaro 1SS, 1LE, NPP, RECAROS
I has the Google Power!
https://www.google.com/search?q=GM+D...cBAnuS4HPDM%3A
hcsi99 is offline   Reply With Quote
Old 03-25-2016, 10:42 PM   #4
domano 68
domano 68's Avatar
Drives: 2014 1LE
Cool, thanks. I searched "cross section". Cut away is a better term to use. Thanks.
Old 03-26-2016, 12:38 AM   #5
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Probably not exactly what you're looking for but here's my video of the flaps opening and closing.
http://youtu.be/QpZe-cVp1yU
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 03-26-2016, 06:03 PM   #6
Dubscamaro
Living Life in MPH.
Dubscamaro's Avatar
Drives: 15 Summit White 2SS 1LE
http://www.camaro5.com/forums/showthread.php?t=180813
Dubscamaro is offline   Reply With Quote
Old 03-30-2016, 01:32 PM   #7
markgws6
markgws6's Avatar
Drives: 2019 Chevy Equinox Premier AWD
Originally Posted by Dubscamaro View Post
Thanks! This was an interesting read for sure. So the valves open are not quite "straight through"...
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43)
markgws6 is offline   Reply With Quote
