Old 03-29-2016, 10:36 AM   #1
C-redfly
C-redfly's Avatar
Drives: 2013 VR vert ZL1
Weird sound coming from the front right
It's really noticeable when the car has been sitting all day and I begin to drive. It sounds like worn bearings or a axle boot that is dried out. Probably something else but that is what it sounds like. A light grinding sound.
Sent from my Nexus 5 using Tapatalk
C-redfly is offline   Reply With Quote
Old 03-29-2016, 01:18 PM   #2
azrickster
azrickster's Avatar
Drives: 2010 Camaro 2SS/RS CGM 6M #38916
When does the sound appear? When you start to roll? When you turn the wheel side to side?
azrickster is offline   Reply With Quote
Old 03-29-2016, 06:22 PM   #3
C-redfly
C-redfly's Avatar
When I accelerate, it's bad at first but lightens up after a few minutes
Old 03-29-2016, 09:34 PM   #4
C-redfly
C-redfly's Avatar
Do you think it could be the wheel hub assembly. It sounds like it sticks after sitting in one spot all day.
Old 03-29-2016, 10:21 PM   #5
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
First thing to do is check to make sure all the nuts are tight, most common one to come loose is the endlinks (check both the top and bottom).. then just go from there..
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 03-29-2016, 10:39 PM   #6
C-redfly
C-redfly's Avatar
Ok will do thanks.
