Old 04-12-2016, 10:59 PM   #1
1LESSCamaro
Drives: 07 Sierra Denali, 15 1LE
AGP kit
I'm getting together the remaining parts to install the kit. Install will be on my 1le so I already have the ZL1 fuel pump. I'm planning on running a low boost setting of 8lbs or so and a high boost setting of 12+. I need some input on a final parts list. Let me know of anything you would add or change.
I have the following:
AGP kit with Borg Warner S256 turbos
85lb injectors
ADM FPCM
G Force II boost controller
Dashlogic (for wideband and fuel pressure monitoring)
KB BAP
NGK Trix7 plugs
O2 extenders
PLX SM-AFR
ZR1 MAP sensor (part number 12592525)
I plan on purchasing:
Meth kit Alky Control
I think that's it. Just trying to get my ducks in a row. Any help would be appreciated.
ETA: Would it be a complete waste of money to get a set of Hooker BlackHeart shorty headers and have them coated?
1LESSCamaro is offline   Reply With Quote
Old 04-12-2016, 11:06 PM   #2
Unreal
Drives: 2006 Z06
BAP for that power level unless you depend heavy on meth. Alky control single or AEM single nozzle is more than enough for 850 or less.
Nick
Corvette Z06 -1200ish rwhp
Old 04-12-2016, 11:26 PM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Dont worry about the shorty headers, the stock manifolds are durable, and will flow more power than your talking about putting to it.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 04-13-2016, 03:52 AM   #4
Glushenij
Glushenij's Avatar
Drives: 2014 Camaro 2SS 1LE
On spark plugs I would go ngk part 3346. They 2.19$ at advance and get plug wires( but not necessary ) and as 1killlerss sad u don't need headers( waste of money) save money for clutch!!!!
AGP TT 807whp 811wtq 13.46psi E85+methanol
Glushenij is offline   Reply With Quote
Old 04-13-2016, 09:09 AM   #5
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
Mine is getting ARH headers because I have an LSX 427 and the outer head bolt bosses interfere with stock manifolds.
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance
1000rwhp
white1LE is offline   Reply With Quote
Old 04-13-2016, 01:15 PM   #6
1KillerSS
1KillerSS's Avatar
I'm going to be in the market for a set of the ARH shorties. I want to change the sound of my engine, that is the only reason. Could you pm me a idle video of the sound of your car once you get them installed and the car is running?
Build thread
Old 04-13-2016, 04:57 PM   #7
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
I would suggest the GFB boost controller as AGP recommends and has setup videos for on youtube. It works very well, but it isn't required by any means, only a suggestion.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 04-13-2016, 06:11 PM   #8
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Tires. Sticky ones.
Unavowed is offline   Reply With Quote
Old 04-13-2016, 10:13 PM   #9
white1LE
white1LE's Avatar
Will do!
13 ZL1 A6
1000rwhp
Old 04-13-2016, 10:48 PM   #10
Sakudog
Sakudog's Avatar
In for a video of those at idle and under boost!
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 04-14-2016, 12:49 AM   #11
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
85lb injectors
ADM FPCM
PLX SM-AFR
Aeroforce fuel pressure sensor
NGK Trix7 plugs
O2 extenders (need suggestions on length)
Meth kit Alky Control ( suggestions on single/dual and size)
Boost a Pump (do I need this?)
I actually would like to know how those headers setup with the AGP kit. I'm currently running them and an AGP kit is in my future.
Old 04-14-2016, 01:00 AM   #12
AGP Turbo
Drives: All things Turbocharged
I can't really tell much difference in the sound.
AGP Turbo is offline   Reply With Quote
Old 04-14-2016, 02:01 AM   #13
1KillerSS
1KillerSS's Avatar
Well that's disappointing, Well I guess that saves me over a grand right there! lol
Build thread
Old 04-14-2016, 08:51 AM   #14
1LESSCamaro
Preference between JMS, Kenne Bell, or MSD? I will not be depending heavily on meth.
Thanks for the info.
I picked up the GFB up from AGP.
