Old 04-24-2016, 06:58 PM   #1
Feeweezy7
Drives: 2011 Chevy Camaro LT1
Post 2011 camaro LT engine misfire
So about last week my car started acting up.. I was on the highway and all of a sudden my dash lights all came on and my check engine light, then I felt a decrease in my speed my acceleration became sluggish.. I went to my mechanic, not a chevy dealers and got the codes read. I had 18 of them a lot of random misfires ex. P0300, P0301 n etc. and had a MAF sensor one also.. Meanwhile I have a aftermarket CAI system in (spectre). When my car is in idle mode it's shaking and doesn't sound good at all.. So far I replaced the MAF sensor, changed spark plugs, and the problem still exists but the codes are reading misfires from cylinder 1,3,5 so my mechanic said let change the ignition coils which I brought 3 of them and replaced them and the problem is still there.. He basically is out of answers and doesn't know what the problem is and told me go to a chevy dealers.. Meanwhile my car isn't under warranty anymore so I'm screwed on where to go next in getting it fixed I need my car asap for work n school.. Please help
Feeweezy7 is offline   Reply With Quote
Old 04-25-2016, 09:56 AM   #2
Tyerius
Tyerius's Avatar
Drives: Camaro V6 2009, VW Tiguan, VW MK1
sry to hear that. Got the same Problem.
When my v6 is on idle at the trafic lights its started to shakin. Whe i hit the gas hardly it goes away untle it gets on idle the it started to shake again.
Code says missfire cyl 1 3 5. maybe u fix it and help me with an answer.
Biggest Problem i live in Germany and in town is nobody that can fix it :(.
greets
Mika
Tyerius is offline   Reply With Quote
Old 04-25-2016, 10:23 AM   #3
Flashpoint135
Flashpoint135's Avatar
Drives: 2016 SS
I had similar issues and it was crap built up on the intake valves. A "top end clean" might help, that's what the dealer will do first.
Flashpoint135 is offline   Reply With Quote
Old 04-25-2016, 10:33 AM   #4
Tyerius
Tyerius's Avatar
thx i take some liqui moly valve cleaner, and try this.
Old 04-25-2016, 11:55 AM   #5
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Have timing chain assembly replaced if over 50k miles in most cases with the LLT, it is just a matter of time before you can jump timing as the chin stretches, etc.
The carbon/coking deposits are most common, but if you have more than 10-15k miles on be aware the large hard abrasive chucks loosened can and will cause engine damage. Installing a Elite E2 or E2-X system when new is the best way to prevent this from occurring. If over 15k miles, we suggest only a manual cleaning done with removal of the intake manifold and valves closed on ports your cleaning. Use crushed walnut shell media blast system or cheaper and as effective the brush method.
over 99% of ALL gasoline vehicles are now GDI, and this is an issue with EVERY automaker no matter what they claim....none have it solved, but all go to great lengths to downplay the severity.
Elite Engineering is offline   Reply With Quote
Old 04-25-2016, 12:13 PM   #6
Feeweezy7
I just got it towed to a shop and the guy is going to do a compression test and go from there, he said with less than 60k he doubt it's a mechanical engine problem. It might be something so stupid that's causing it but he said he will read the cars data and attack it from there.. He did say something bout a vacuum that might be causing the problem also but he said he will attack it and give me a call and go from there..
Old 04-25-2016, 09:53 PM   #7
reaper2e77
Drives: 2011 Camaro RS
Definitely sounds like carbon build up. Happened to mine. Dealer had to so a complete engine flush to remove all the junk in the engine. Still pissed about it and currently fighting with GM about. They have not been much help at all, but that is another story.
reaper2e77 is offline   Reply With Quote
Old 05-04-2016, 06:53 PM   #8
Feeweezy7
greets
Mika
Did you get your issue resolved? After about 2 weeks my car being in the shop and come to find out the cause for the misfires was a broken valve spring in one of my cylinders.. A compression test will help determine the problem and a mechanic can go from there.. I was able to get it fixed without any extra work needing to be done for about 800$
Old 05-04-2016, 06:54 PM   #9
Feeweezy7
It was a broken valve spring in one of my cylinders causing all 3 on one bank to misfire I got a compression test done and the mechanic was able to go from there to find the problem after removing the valve cover
Old 05-08-2016, 05:17 PM   #10
Tyerius
Tyerius's Avatar
Ok tomorrow I got the diagnose at the Chevy dealer, hope they find some.
Thx
Old 07-23-2018, 10:22 PM   #11
Ilsarafi
Drives: 2011 Camaro LT Silver, black stripe
How did you fix it. I have the same problem and it’s driving me crazy!
Ilsarafi is offline   Reply With Quote
camaro, camaro engine cover, camaro lt/rs, misfires
