Old 10-01-2009, 12:34 PM   #1
Jason 98 TA
Drives: Camaro
PRC CNC Ported LS3 Heads Going on the Engine Dyno Today!!
Guys we're porting the stock LS3 cylinder heads on our engine dyno LS3 today! We'll post dyno graphs asap showing power gains from cnc porting your stock castings.
Anyone wanna take guess at what power will be added with cnc porting the heads & no milling for extra compression?
I'll get info & dyno sheets up later today!
Jason 98 TA is offline   Reply With Quote
Old 10-01-2009, 12:46 PM   #2
Pope Designs
Drives: 2013 ZL1 Rally Yellow
15HP
Pope Designs is offline   Reply With Quote
Old 10-01-2009, 12:50 PM   #3
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
I woudl like to see 20HP at the wheels, so that would be 24-25 on an engien dyno. That is what I was told to expect from some very reputable porting companies.
You say you are using the PRC ones? Just tryign to keep track of what is already tested, as I will also be doing some on my car, and could use a different company so that we have multiple ones to compare.
ZZcamaro is offline   Reply With Quote
Old 10-01-2009, 12:50 PM   #4
Jason@RPM-Motorsports
Jason@RPM-Motorsports's Avatar
Drives: 98 WS6
30 HP on the engine dyno
Jason@RPM-Motorsports is offline   Reply With Quote
Old 10-01-2009, 02:07 PM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Have you dynoed the GM CNC L92 heads?
Old 10-06-2009, 03:16 PM   #6
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Did I miss the results elsewhere on the site?
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-06-2009, 04:47 PM   #7
rex113
rex113's Avatar
Drives: 2010 2ss silver/cyb
I think I read somewhere that GM did a very good job with the LS3 heads so if its more than 10 or 15 I would be happily surprised.
rex113 is offline   Reply With Quote
Old 10-06-2009, 04:55 PM   #8
Robin Lawrence
Robin Lawrence's Avatar
Drives: 2010 Camaro 69 Nova
I agree. We installed the GM Performance Parts heads and there wasn't a huge jump like you would expect.
If you look at the flow numbers in the catalog you see that they pick up 5 to 15 CFM. The big gains are all at the higher lift numbers.
Since it's now October 6th and no dyno numbers I would say that they also didn't see a big jump in the numbers.
The LS3 is a bad boy from GM. The days of huge gains are over.
Robin
Holley Performance Products
Robin Lawrence is offline   Reply With Quote
Old 10-06-2009, 10:10 PM   #9
Drives: 98 WS6
I talked with Jason and it did pick up right at 30 on the engine dyno
Old 10-06-2009, 10:15 PM   #10
GQ4Life
Drives: 2010 Camaro SS LS3
really.. before and after dyno sheet?
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 10-07-2009, 03:07 AM   #11
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Old 10-07-2009, 11:28 AM   #12
Jason 98 TA
Drives: Camaro
What GM's heads do & what other brands heads do could be something completely different. I don't know what you've seen power gains from the GM cnc heads, but we've had pretty good luck with our port.
Sorry for the delay getting the graphs up guys, this LSx shootout stuff has me working double time on other stuff! It's bad when you have the data & don't even take time to post it for over a week! LOL
Enjoy
Old 10-07-2009, 11:29 AM   #13
Jason 98 TA
Drives: Camaro
Not bad for under $750 exchange!!!!
The heads maintain stock valve drop so your not limiting yourself to smaller camshafts to maintain good p/v!
Old 10-07-2009, 06:33 PM   #14
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
How would these do (power gain) on say a TVS + cam motor? I would expect more power, just curious as to how much more...
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 02:04 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 05:00 PM
