Old 05-27-2016, 09:06 AM   #1
kstormoen
Drives: Camaro SS2 L99
Reading alcohol content with interceptor gauge
I have the interceptor Gauge for checking my Alcohol Content and it displays it kind of erratically. The number will switch quickly by about 3-4%. I'm not sure if it is just not reading it accurately or maybe I don't have my sensor wired up correctly. I'm hoping that someone who is using it could chime in here. Does your reading stay pretty constant or jump around? I have the JRE flex fuel sensor pinned into the ecm and the gauge is reading from the ODBII. Thanks for any help here.
Keith
kstormoen is offline   Reply With Quote
Old 05-27-2016, 10:18 AM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
My flex fuel sensor does the same thing. I just assumed it's normal
ttshovel is offline   Reply With Quote
Old 05-27-2016, 03:28 PM   #3
Unreal
Drives: 2006 Z06
Strange, mine reads rock solid, no issues at all. I would double check all the connections.
Nick
Corvette Z06 -1200ish rwhp
Old 05-27-2016, 04:04 PM   #4
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Mine is solid set on a single number unless i just filled up
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 05-27-2016, 04:06 PM   #5
kstormoen
Those that are reading constant, what gauge are you using? I have an innovate gauge on my mustang and it reads constant. My interceptor on the Camaro jumps around. Wondering if it is the difference of the gauge. Thanks for the input.
Old 05-27-2016, 07:14 PM   #6
Unreal
Drives: 2006 Z06
Dashlogic, or HP tuners.
If it is jumping around, could be an aeroforce issue, but I doubt it. Should be a constant out from the ecu.
Nick
Old 05-31-2016, 02:00 PM   #7
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
So I can read the e85 % on HP tuners? do i just do this where I would be data logging?
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 05-31-2016, 03:12 PM   #8
fif_gen_powa
You need to have a flex fuel sensor installed and pinned to the ecu. Than there are some tables that need to be unlocked to utilize it using hp tuners
8.3@164
Old 05-31-2016, 04:14 PM   #9
blake2010ss
Im having one installed by FSP so i imagine all that will be done there so they can tune it.
1093/1066
Old 05-31-2016, 09:15 PM   #10
Unreal
Drives: 2006 Z06
Yes, just plug HP tuners in, and log alcohol content. It isn't like it changes unless you just filled up.
Nick
Old 05-31-2016, 09:31 PM   #11
ghosted
BCS Auto
ghosted's Avatar
Drives: 2015 Camaro 1LS
My Autocal reads the percentage pretty solid. It'll only vary 0.2 - 0.4% at any given time.
BCS Auto on Facebook - - - Follow me on Instagram @datv6tho & @officialbcsauto
ghosted is offline   Reply With Quote
Old 05-31-2016, 09:55 PM   #12
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Matt will be able to show you how to do the same with your software. Just because he can log the information within HPT, does not mean YOU can, until you setup your PIDS. He will do whats needed within the tune, but YOUR scanner will need to be configured.
I'm not too sure about version 3.0 compared to the newer stuff, I think in the newer version of HPT all you need to do is enable it in your table, I don't believe you need to manually input the PIDS, they may already be there, just a matter of enabling them. I could be completely wrong about that, but from what I have seen of 3.0 they have done away with a lot of that stuff.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-31-2016, 11:34 PM   #13
Unreal
Drives: 2006 Z06
Just goto the table, right click, add parameter, select alcohol content, done.
Nick
Old 06-01-2016, 08:09 AM   #14
blake2010ss
awesome, thanks guys.
1093/1066
