Old 10-02-2009, 09:41 AM   #1
Downwithopp
Downwithopp's Avatar
Drives: 2010 Black SS
How to properly install Defenderworx bowties!
What is the actual process to installing the Defenderworx bowties? I found a couple guides online about how to remove the stock ones, but the ones that I got have just the tape on the back, with no pins.
Any help would be much appreciated.
Downwithopp is offline   Reply With Quote
Old 10-02-2009, 10:26 AM   #2
Defenderworx
Accessory Guru
Drives: 2010 Chevrolet Camaro
For the Front, reach behind the grill and pop the bowtie out by pushing the brackets through the grill towards you. Use a flat screwdriver and pop the gold piece from chrome. Replace the Gold with the replacement bowtie, and pop back in to the slots. For the Rear, take a drill and slowly drill a hole in the center of the gold bowtie on the back. Take a pick and pop the Gold piece out from the chrome backing. Replace the Gold with the replacement bowtie and you should be all set.
If you have any issues, please call Brian at DefenderWorx @ 714-630-9700. He has done this process over 50 times.
Defenderworx is offline   Reply With Quote
Old 10-02-2009, 10:49 AM   #3
Downwithopp
Beautiful, exactly what I needed. Thanks a ton!
Old 10-02-2009, 10:59 AM   #4
Defenderworx
Accessory Guru
No problem. If you come across any hurdles, just call Brian. He can help...Post pictures when you get them installed....
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 08:25 PM
DefenderWorx or anyone who knows install... GRM RPR Cosmetics and Lighting Modification Discussions 18 10-29-2010 12:21 AM
Will my dealer install bowties? G.E. Cosmetics and Lighting Modification Discussions 2 08-20-2009 10:07 PM
Defenderworx bowties available NOW! Camaroyoung Cosmetics and Lighting Modification Discussions 26 07-30-2009 11:38 AM
Defenderworx blacked out Bowties sigma_1966 Cosmetics and Lighting Modification Discussions 48 07-23-2009 08:22 AM
