Old 06-26-2016, 08:08 PM   #1
loves_bruins
Drives: 2010 Camaro SS2
Best rear-end for 2010 L99
Hello,
I'm a noob. My L99 has the stock 3.27 I believe in the rear end. I want to increase HP, so I was thinking of 3.91. But then after reading on this forum the 3.91 is a little heavy on the torque, so I would more thank likely smoke more often that I want. So I was looking at 3.70. I have 22" wheels in the summer. In the winter I use 19" Blizzaks (shoot me now for even running it in the winter). I'm hoping to remedy this by the end of summer with a beater car for the winter so I don't have to use the Camaro.
Anyway, feedback is obviously appreciated.
Your friend for life
loves_bruins is offline   Reply With Quote
Old 06-26-2016, 08:15 PM   #2
flyer08
Drives: 2010 2SS/RS
3.91 won't gain you hp, probably decrease in most cases if your just looking for dyno numbers. I just did my 3.91s and even the wife said car is fun to drive now
flyer08 is offline   Reply With Quote
Old 06-26-2016, 11:59 PM   #3
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
391s are great in the l99....best mod ive done to the car...its gets going in a hurry. They are alot more fun at the track then the stock gears...
rontammy0 is offline   Reply With Quote
Old 06-27-2016, 06:47 AM   #4
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
Gear will NOT gain you any hp, period. But it can help you get into your power range a little faster.
Old 06-27-2016, 08:29 AM   #5
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
Like others have said, gears will not gain any horsepower, but you will feel the power you have quicker. Contrary to rontammy0 said, many people opt for 3.73 gears in a L99. The primary reason is if you plan on going with major power then you will not blow the tires off the car as regularly with 3.73 as you would with 3.91. That being said, rontammy0 is a person who actually has 3.91 gears in his car so you might put a little more faith in him than me because I'm still running the factory rear end all the way through.
Check out my build thread
Old 06-27-2016, 10:09 AM   #6
havelegs
havelegs's Avatar
Drives: 24 LT1 M
How's it possible to decrease the HP from the rear end gear? Does not compute.
havelegs is offline   Reply With Quote
Old 06-27-2016, 05:17 PM   #7
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Originally Posted by loves_bruins View Post
Hello,
Greeting and welcome to C5! As others have said, gears neither add nor reduce actual "horsepower". They will, however, change the way your car utilizes available HP. Sounds like you just want more acceleration and shift firmness, which changing gears can do.
Go to this thread and read all about gears: http://www.camaro5.com/forums/showthread.php?t=95142
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 06-27-2016, 05:28 PM   #8
JLBIII
JLBIII's Avatar
Drives: 2010 RJT 2SS
Had 3.91's in my 2010 L99 since 2011. Lots of fun and more responsive driving on the street. Go for it!
JLBIII is offline   Reply With Quote
Old 06-27-2016, 05:56 PM   #9
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Car will feel much torquier...you will also hit higher rpm's while cruising on the highway, hence lower your mpg's...City driving will be better in everyway
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 06-28-2016, 03:08 AM   #10
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
LPE AAM 3.70's. Perfect with my supercharger.
SS PANTHER is offline   Reply With Quote
Old 08-01-2016, 10:25 PM   #11
JS440
Drives: Black 2014 ZL1 m6 coupe
Dropped a half second and gained 3 mph on my quarter mile times just by swapping to 3.91s
JS440 is offline   Reply With Quote
Old 08-01-2016, 10:30 PM   #12
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
Oh yeah? Well I can one up that. Not only did I drop half a second on my quarter mile times when I switched to 3.91's, but I also dropped a grand on new tires.
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 08-01-2016, 10:35 PM   #13
flyer08
Drives: 2010 2SS/RS
http://www.camaro5.com/forums/showthread.php?t=368121 People smarter than me discussing it for 4 pages
3.27, 3.73, 3.91, gears swap
