Old 10-04-2009, 05:25 PM   #1
ajs69cam
ajs69cam's Avatar
Drives: 2010 Camaro
Tire Pressure ?? WT( Heck )
On Star informs me that my tires are in need of some Air Pressure.
The LF-31, RF-31, LR-32, RR-32. Three weeks ago I had put 36 lbs
in each of the tires. Ok, so now my wife and I go out to the garage
and proceed to put air into the drivers side front tire. (Remember,
it's at 31 lbs) She is looking at the Information Screen and tells me
that the passenger side air pressure is going up to 34 lbs. I told her
that it can't be, because I'm on the drivers side. She said OK, but
the passenger side air pressure is going up on the screen. I continue
to put more air in the tire and she tells me that the passenger side
now shows to be at 36 lbs. WHAT THE HECK! I now go to
the rear drivers side, which is at 32 lbs and I proceed to start putting
air into that tire. My wife then tells me that the screen is showing
that the rear passenger side is starting to show an increase in air
pressure (which is the opposite side that I'm putting air in). I then
started putting air in the tires on the passenger side and the
air pressure showed to be increasing on the drivers side,
according to the information screen. Well, I did finally put 36 lbs
in all of my tires, but is anyone out there having the same problem,
and if so, what did you do to correct it? (I'll probably end up going
to the dealership). These are the factory tires that came
with my 2LT/RS.
ajs69cam is offline   Reply With Quote
Old 10-04-2009, 06:15 PM   #2
ajs69cam
ajs69cam's Avatar
Drives: 2010 Camaro
Thx-- But why is it reporting pressure for a tire on the opposite side?
Old 10-04-2009, 06:18 PM   #3
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Sensors are confused on which position they are in?
scrming is offline   Reply With Quote
Old 10-04-2009, 06:19 PM   #4
rickerda
rickerda's Avatar
Drives: 2010 Camaro 2LT RS
Have the dealer reprogram it, it sounds like someone rotated your tires.
rickerda is offline   Reply With Quote
Old 10-04-2009, 06:21 PM   #5
scrming
scrming's Avatar
2LT/RS... no rotating... or at least you are not supposed to...
Old 10-04-2009, 06:59 PM   #6
ajs69cam
ajs69cam's Avatar
Drives: 2010 Camaro
Hey, That's right! I've got 10,000 miles on the car already, so OnStar, 2000 miles ago, informed me to rotate the tires. But because I've got larger tires on the back, Discount Tire rotated them side to side. Maybe that's why I'm getting a mixed up reading. I guess I'll be taking it back to the dealer to get it reprogrammed. Thanks for your help guys!
Old 10-04-2009, 07:10 PM   #7
Y2Breeze
Y2Breeze's Avatar
Drives: 2010 1LT/RS CAMARO
Is it 245 in front and 275 in back on RS?
2010 1LT/RS CAMARO #45387 - NMGGH6 - V6/M6 - AQUA BLUE METALLIC, BEIGE INTERIOR, C&C PACKAGE
1100 : 10/06/2009 2000 : 08/10 2500 : 08/11 3000 : 08/11 TPW 09/07 3100 : 08/24 3300 : 08/24 3400 : 09/01 3800 : 09/14 - 2G1FF1EV1A9145387 4000 : 09/11 4200 : 09/16 4200 : 09/23
Y2Breeze is offline   Reply With Quote
Old 10-04-2009, 07:14 PM   #8
Frayles
Drives: 2020 Cadillac CT5 V and 87 Buick GN
I think there is a way listed in the owners manual to do the sensor relearn yourself. It should take you no more than five minutes to do and there is absolutely no heavy lifting. Save yourself a trip to the dealer.
2SS, Nightfall Gray, A8, MRC, NPP, NAV, Blk Bowties
Gen 6
1100 01-22-2016
2000 03-22-2016
3000 03-25-2016 TPW 4/11
3400 04-01-2016
3800 04-08-2016 - Built
4200 04-08-2016
6000 04-20-2016
Gen 5
1100 04-22-2009
2000 05-15-2009
2500 05-19-2009
3000 05-21-2009
3400 06-10-2009
3800 06-18-2009
4150 06-18-2009
4200 06-19-2009
4800 06-29-2009
4B00 06-30-2009
5000 07-10-2009!!!
Frayles is offline   Reply With Quote
Old 10-04-2009, 07:20 PM   #9
97one
97one's Avatar
Drives: 2016 & 1967 Camaro, 2015 Impala, +1
You don't have to go to the dealer, unless you don't like to do things yourself.
See pg. 9-60 in the manual.
It tells you how to do it by increasing or decreasing the tires air pressure.
97one is offline   Reply With Quote
Old 10-04-2009, 07:24 PM   #10
scrming
scrming's Avatar
hmmm... could have sworn some one told me the tires were directional... but just went out and checked and they don't appeared to be marked directional... sooooo... guess you can rotate them side to side????
Old 10-04-2009, 07:24 PM   #11
ajs69cam
ajs69cam's Avatar
Drives: 2010 Camaro
I've been told by dealership, Onstar and Discount Tires that it's 36lbs all
4 tires. What that converts in metric?? Don't know--
Old 10-04-2009, 07:29 PM   #12
97one
97one's Avatar
245 & 275 are the tire sizes..........Not air pressure.
Old 10-04-2009, 07:29 PM   #13
ajs69cam
ajs69cam's Avatar
Drives: 2010 Camaro
Thanks-- That is just what I needed-- The page ##'s--
Old 10-04-2009, 07:31 PM   #14
97one
97one's Avatar
Yes..........
Tire Pressure Problems Matster Canada 14 10-03-2009 07:11 AM
Tire Pressure Monitoring Dentyneice Wheels and Tires Talk Sponsored by The Tire Rack 8 08-14-2009 07:42 AM
How does onstar know what tire pressure I have? FLYNNZL1 Wheels and Tires Talk Sponsored by The Tire Rack 8 08-09-2009 03:11 PM
Resetting TPMS Tire Pressure System jvmax Wheels and Tires Talk Sponsored by The Tire Rack 4 07-10-2009 01:37 AM
Tire Pressure toehead93 Dragstrip and Launch Techniques Discussion 4 06-09-2009 01:24 PM
