![]() Drives: 2012 Bumblebee Join Date: Apr 2016
Got my after market headers removed but check engine is still on.
I got my aftermarket headers removed and my stock headers put back in but the check engine light is still on, I've driven it about 120 miles so far, is it supposed to just turn off on its own eventually?
edit* The aftermarket headers were stainless power and I have NPP exhaust right now. O2 sensors were swapped from long tubes to oem. The codes pulled from autozone were P0420 and P0430 repeated. Update* CEL went away on its own after I drove it a little over 200 miles. Last edited by rainofcastamere; 07-13-2016 at 11:25 PM. |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Ok first off let's start by telling the back story. What headers? Any catback? Did you remove any sensors? Did you have the car tuned? Did you pull the codes that tell you what was off?
El Duderino
https://axleaddict.com/auto-repair/C...rs-For-Dummies
Might clear on it's own after a while. Could try a fuse pull or a battery disconnect and see if it comes back...
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
You have to disconnect the battery...try disconnecting it overnight.
Pity a man in familiar places, who yet feels like a stranger.
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS M6 Join Date: Nov 2014
Or it will probably go away on it's own. The ECU will shut it off after x amount of successful system checks, not sure how many for emission faults on this car though. |
#7 |
![]() ![]() Drives: 2011 Camaro 1SS Join Date: Feb 2016
parts store will also clear if you do not have a scanner.
2011 SGM Camaro 1SS/RS A6 - Vengeance Racing built/tuned. 590RWHP/560RWTQ, ADM LSA Conversion, 2.5 Grip-Tec, ZL1 fuel pump, ADM FPCM, FIC1000, VRPD2 Cam and LS3 Conversion with all the internal goodies, American Racing 1 7/8 Headers, no cats, SW Retro Cat Back, ADM Intake, AFCO HX, Varimax Pump, Rotofab Reservoir, B&M Transmission Cooler, VMAX TB, Elite Engineering CC, BMR LCAs, Trailing Arms, Toe Rods, DSS 1000hp axles, ZL1 Bumper and Sideskirts, Night Owl Halos, Matte Black 20" Rohana RC-22 with 20x10-275s/20x11-315s, R1 Concept Premier Drilled/Slotted Rotors, Hawk Ceramic Pads.
#8 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
did you ever read the code before you installed these headers??
normally after making repairs, you reset the light and see it if comes back. If yes, need to read the code. the shop that installed the headers should have done this for you. if so, you need to read the code. |
#9 |
Step one: Disconnect your battery for at least 3 hours. Reconnect and see if the CEL has gone away. If not... go to Step Two (though I don't know what that would be).
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
#10 |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS/RS M6 Commemorative Join Date: Apr 2014
#12 | |
From autozone: P0420 - Catalyst System Low Efficiency P0430 - Catalyst Efficiency Below Normal P0420 - Catalyst System Low Efficiency P0430 - Catalyst Efficiency Below Normal |
#13 |
![]() ![]() ![]() ![]() Drives: 2011ss/rs camaro Join Date: Sep 2011
If you had no cel with headers the car was tuned and rear sensors turned off. When you reconnected the rears sensors the cel is present. Tune needs to be put back to stock.
#14 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS Victory Red with white st Join Date: Jun 2016
