Old 10-07-2009, 08:47 PM   #1
faninc
Drives: 2010 Camaro RS in SIM
Wheel lock observations...help please
Hi ALL,
Wheel lock question...
I recently bought the Mcgard and sent them back and just installed the Gorilla type locks #61641. Here is what I notice with both- the stock lugs have the acorn edge at the bottom but a very wide taper to them. Both the McGard and even the Gorilla have narrow tapered acorn bottoms.
When I tighten the Gorilla the lug nut, looks like it is going through the hole in the rim and tightening on the bolt but appears not to making contact and pulling the rim in?
The GM lug with the wide tapered acorn end, screws in and through the hole BUT then you see the wide taper appearing to sit on the outside of the rim and pulling in the rim.
So the question is does the gorilla pull in the rim to the lug or is the lug nut just going through the rim role and tightening on the lug itself?
faninc is offline   Reply With Quote
Old 10-07-2009, 09:25 PM   #2
adk46r
PROUD MARINE DAD! OORAH!!
Drives: 2010 IOM 2SS/RS,1967 Murina Blue RS
I have the same Gorilla's on mine and I've got a little over 2K miles on her with no problem whatsoever. I did notice the same thing when I was putting my locks on but if you look really close they do pull in the rims, just don't forget to re-tighten/check after a 100 miles or so!
adk46r is offline   Reply With Quote
Old 10-07-2009, 09:49 PM   #3
faninc
Thanks adk46R. Funny that no one has made the proper tapers yet for the new 2010 camaro it has been out for 7 months now. Gorilla, Mcgard are you all listening?
Old 10-12-2009, 08:06 PM   #4
Wileytrigger21
Wileytrigger21's Avatar
Drives: 2010 CGM 2LT / RS, Blk 1SS/RS
Correct part number for the Gorilla locks is 71641N. Just found it on a google search.
Wileytrigger21 is offline   Reply With Quote
where do you jack up the car if you have a flat or oil change /also wheel lock photos camarossrs2150 5th Gen Camaro SS LS LT General Discussions 30 11-10-2009 12:45 PM
2SS Silver Ice Metallic at ATL Car SHow Cmurf_SS Camaro Photos | Spyshots | Video | Media Gallery 40 11-09-2009 10:38 PM
Steering wheel leather cracking!! meliss7567 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-17-2009 03:13 PM
Lug wrench in SS? + wheel lock question... DDustiNN Wheels and Tires Talk Sponsored by The Tire Rack 8 09-05-2009 01:52 AM
Lug wrench in SS? + Wheel lock question DDustiNN Wheels and Tires Talk Sponsored by The Tire Rack 2 09-04-2009 05:16 PM
