Old 11-07-2016, 08:29 PM   #1
loves_bruins
Drives: 2010 Camaro SS2
How to remove the plastic tab that holds O2 sensors
Hey gang
I'm replacing my headers and have to remove the 4 O2 sensors. I broke that stupid yellowish tan tab on both rears. How can I remove the front green ones without breaking them?
loves_bruins is offline   Reply With Quote
Old 11-07-2016, 09:07 PM   #2
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Try using a very small flat head screwdriver to press down the lock and wiggle it off/out
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 11-07-2016, 09:12 PM   #3
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I broke the green things for the rear and almost did for the front. The rears I just zip tied. I tried using neelenose pliers to get the tab out....... Didn't work.
Old 11-07-2016, 11:43 PM   #4
2012OrangeVert
2012OrangeVert's Avatar
Drives: 2012 Orange 2SS/RS Convertible
I just pulled hard on them with my fingers. Sideways. Maybe some needlenose pliers would work. They do suck. Seems like overkill. The tab holds them. Also you have to pull down on the whole thing first to remove it from the block. Then you have a little more room to wiggle it.
2012OrangeVert is offline   Reply With Quote
Old 11-08-2016, 08:26 AM   #5
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
Pull HARD. The driver's side one is easy, the passenger side one is more difficult because you need to pull towards the firewall.
Check out my build thread
Old 11-08-2016, 08:43 AM   #6
loves_bruins
Won't that break them? I was trying to see if I could keep them for when I reconnect.
Old 11-08-2016, 04:26 PM   #7
pyroguy
pyroguy's Avatar
Drives: ABM #832
No they should lock back with no trouble. However, the O2 extenders are locked on by a clip and should be fine without the extra security clip. Mine have been running fine for over a year now without the clip locked back on.
Old 11-08-2016, 09:36 PM   #8
2012OrangeVert
We mean pull on them to remove them from the block. Then you have a little more room to get at the locking tabs. If you pull around on them , they should move around. You are not trying to get the tab off at this point. You are just removing it from a sliding holder that is hooked onto the back of the block. Kind of like a cordless drill charger. You slide the battery into, and slide it back off. Same concept, only way smaller. At that point it is no longer buried against the block, and you can get at those tabs. Then you pull the tab out from the plastic clip. Then you just take a small flat head screwdriver and pull up the tab and slide out the connection. Once you get it you will understand. Seems you have to just do it once, then it is all clear. Hard to explain to someone though. Maybe easy to explain on the phone. If you continue to have trouble , you can pm me and I will give you my number .
Old 06-21-2025, 03:02 AM   #9
2ss2moon
Drives: 2014 Chevrolet Camaro 2SS
bro! i replaced my passenger side o2 upsteam i think it was and i cant see anything behind the engine block where the sliding holder is located...what should i do man any tips?!
2ss2moon is offline   Reply With Quote
Old 06-21-2025, 07:29 AM   #10
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Small auto mirror and flashlight. You’ll find it
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
o2 sensor connector
