![]() Drives: 2010 camaro Join Date: Oct 2016
L99 exhaust
my car currently has a stock exhaust, ive been doing research as to what aftermarket system to put, and im set on an axleback system. However i keep seeing that the car will drone, i have no expierence as to what drone is or what it sounds l like, but i wouldnt want to be annoyed while driving, lol. i found that the solo j pipes are really good, anyone have any feedback for this type of system? i also like the way the borla S type sounds as well. Something not too aggressive, just gives a note of a v8.
![]() Drives: 2014 2SS/RS Join Date: Jan 2014
My experience...
I had a local muffler shop take off the suitcase mufflers and re-weld the tips back on the new chunks of pipe (usually referred to as a 'Muffler Delete'), and bought a Range Device. I've had both for over two and a half years and am very happy with the results. I have not experienced any drone at all so far. I've taken a couple of highway trips, and to me, the interior noise level is actually a little lower with the Range installed. Engine is just smoother running on all eight, as opposed to four! That's just my experience, I'm sure others will add theirs as well :-)
Keeper of “THE list”
Solo is AWESOME! I have their Mach XL catback and before I got long tube headers the sound was great. Now with headers it is incredible! If I had to do it again I'd still go with them. Also, I still have AFM enabled and still no drone, even with headers. There are some that just go with their axle back exhaust and love it like I love my catback, I just didn't want the stock clunky resonator nor did I want to cut up my exhaust and hope I cut at the correct spot.
![]() ![]() ![]() ![]() Drives: 2010 2SS/RS L99 IBM silver stipes Join Date: Dec 2015
Def have the resonators removed and install an x pipe. Other than that, it;s whatever you like
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough.... |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Black L99 2SS/RS Join Date: Mar 2014
Solo is very mild
#6 |
![]() Drives: 2012 SS Red w/ black rally stripes Join Date: Jan 2015
Solo !
I would recommend the Solo exhaust if drone is a concern. My SS is cammed, headers with high flow cats and I retained the factory resonator. I replaced the factory mufflers with the Solo axle back. There is no drone, it is not loud inside the car while driving normal. It is loud behind the car and it sounds mean when you start it. The cam is noticeable to everyone, I get lots of compliments. Now when you go WOT it is loud. The Solo system is a muffler delete with J-pipes to prevent the drone.
2012 SS Camaro, Victory Red w/black rally stripes, SLP front splitter, ZL1 Rocker panels, ZL1 Add-ons Stealth Wickerbill, L99, Magnuson Heartbeat supercharger, 65 lb. injectors, 87 mm pulley, ZL1 fuel pump, ADM FPCM,1 7/8 Texas Speed long tube headers, v-max ported throttle body, Rotofab cold air intake with Apex scoop, Apex catch can, MSD plug wires, AEM AFR and Boost gauges, GPI SS1 VVT Cam, HP tuners with remote tune by Ryan at GPI, Solo axleback exhaust w/j pipes and stock resonator.
#7 |
![]() Drives: 2013 Camaro 2SS/RS Join Date: Apr 2014
i did rear muffler delete and shorty headers nice rumble no drone this way you get headers too i probably spent $300 total
2013 Camaro SS Victory Red/Black Stripes
#8 | |
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
I also run the Solo. Had it when stock, then headers and cam and now 418 strocker. Sounded great on all of them, no drone when you get on it they'll now your coming.
#10 |
![]() Drives: 2017 ZL1 A10 Join Date: Sep 2014
Current: 2017 ZL1 A10 previous: 2019 1SS A10 previous: '14 L99, CAI intake, vmax ported tb, e85 kit, stage 2 cnc heads, speed engineering long tubes, custom high flows, resonated x pipe, muffler delete, qtp cut outs, gpi ss3 vvt Cam, zl1 pump and injectors, fti triple disc, mayhem motorsports trans cooler and tune, ngk spark plugs +red msd wires, 3.91 gears. Past: '12 LFX, full bolt ons + E85, 302hp/267tq |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
I have the Solo Axle back also and I'm pleased with the sound. Not very loud but much but much better than stock.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
#12 |
Instagram: Sangstah
Had my mufflers deleted with the factory resonator intact for about $120 and it sounds great with some great rumble. I still want it louder so I will be going with an X-pipe and resonator delete next, I love the sound!
#13 |
![]() Drives: 2014 Camaro SS/RS, L99 Join Date: Feb 2011
I went with the mbrp cat back initially then added the range device. Personally i didnt care for the range device. I experienced all the little quirks people describe such as not starting every month or so. Happened one too many times when out with my wife so i ditched it and ended up getting long tubes and a tune. If i had to do it all over, i would go long tubes and tune first then pick mufflers for the sound. The mbrp is mild without long tubes, but perfect with long tubes. Tame low rumble tone at idle but nice growl when you mash the gas.
2014 Camaro SS, L99
MBRP catback, CAI cai, Stainless Power LTs HFCs, tuned by KP Racing, Rohana RC7's, Z28 spoiler. Last edited by JWade; 11-17-2016 at 10:12 AM. Reason: Edit |
#14 | |
![]() Drives: 2013 SS Camaro Join Date: May 2016
1st...muffler delete with straight pipe & resonated tips...definitely a nice improvement from stock 2nd..(deleted factory resonator) installed magnaflow resonated x pipe did not make it louder.....but it has a deeper tone similar to corvette Still not loud as I want but when u get on the gas 😊. I'm thinking about swapping out the magnaflo to : true xpipe with some flowmaster mufflers Sent from my SM-N920P using Tapatalk |
