Old 10-16-2009, 05:49 AM   #1
multiSS
multiSS's Avatar
Drives: 69 SS396 chevelle 2010 2ssrs camaro
Exclamation Clicking sound from rear axle
  • Since I purchased my 2SS-RS LS3 6S I have noticed some clicking sounds coming from rear axle area on acceleration and decceleration. Local gm dealer found that the axle hub to axle spline nut was loose. This was allowing the hub to turn slightly on the spline causing clicking noises. Simple fix, but if you think you have this problem chech it out right away. If the nut comes off, so does the attached wheel!!!
multiSS is offline   Reply With Quote
Old 10-17-2009, 05:48 PM   #2
camarotoofast
VIN #586 is Home
camarotoofast's Avatar
Drives: 00 Z28 Camaro 69 camaro 81 cam
Send a message via Yahoo to camarotoofast
My camaro was doing the same thing, the dealer replaced left shaft and replaced both nuts last week. I'am at 2900 miles.
*On my invoice it said
Found noise from loose axle to hub allowing splines to pop
called TAC# 11034922
was directed to replace left axle asm for this concern
replaced left rear axle asm. and install and torque new nuts on both axles.
That would suck if a wheel come flyN off on the freeway for a torque issue.
VIN # 586 is home
1ss,blk/blk,poilsh rims,B.A.upgrade,a6,stainless works catback.vararam more-to-come
camarotoofast is offline   Reply With Quote
Old 05-27-2010, 10:06 AM   #3
Yellowcamaro
Yellowcamaro's Avatar
Drives: 2010 RS Transformer Editon
I have the same problem i just got done at gm, they said it was really nothing they ordered two washers and two nuts and then cleared me to drive 1300 miles to utah.
Yellowcamaro is offline   Reply With Quote
Old 05-27-2010, 12:23 PM   #4
SS Mike
SS Mike's Avatar
Drives: 2010 Camaro SS/RS CGM M6
I need to know what kind of clicking sound this was. I have had a click from what sounds like the rear of my SS almost since new. It only happens when taking off from a complete stop though, forward or reverse. Was this the sam eor similar for you guys? Thanks for your help.
Vortech V-3 Kit, ARH LT's, Custom Exhaust, Aeromotive A1000 Fuel System, Custom Tune - 582 rwhp 533 rwtq
22" Modulare H2 Wheels, CF Hood, Trunk, Spoiler & Roof by Carbon by Design, Custom Steering Wheel from P-Factor
Brembo GT BBK, Alpine INA-900, Alpine Type-R Speakers, Hurst Shifter, APR Splitter, Custom Quad Tip Diffuser
CKS C1 Coilovers, Falken 452 Tires, 265/35/22 & 285/35/22, Custom Grille, AAC Halos, and much more to come!!
SS Mike is offline   Reply With Quote
Old 05-27-2010, 01:32 PM   #5
Russell James
Russell James's Avatar
I'll wager 37 cents the wheel will not fall off.
The hub is bolted to the knuckle, and the rotor is not going anywhere with the caliper still bolted down...
Old 05-27-2010, 01:39 PM   #6
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Drives: 2SS/RS - IBM LS3 M6
Same....
gr8daneh is offline   Reply With Quote
Old 05-27-2010, 01:49 PM   #7
Yellowcamaro
Sounds like the same to me
Old 05-27-2010, 04:53 PM   #8
SS Mike
SS Mike's Avatar
Originally Posted by gr8daneh View Post
Same....
Excellent!
I've also noticed a clicking coming from one of the wheels (I believe) that responds to the speed I'm going. If I'm going real slow I can hear 2 or 3 clicks for every rotation of the wheels. Anyone else getting anything like that? Kinda sounds like as a kid when I would put a card on my bike so it made noise when it hit the spokes.
Old 05-27-2010, 06:00 PM   #9
Yellowcamaro
Excellent!
I have not heard this one yet...is it coming from the back or front?
Old 05-27-2010, 07:34 PM   #10
SS Mike
SS Mike's Avatar
Honestly can't tell. Could be anywhere. I can only really hear it when next to a wall, so I'm inclined to say it's on the driver's side, but can't tell fromt or back.
Old 05-30-2010, 05:04 AM   #11
BruceJames
Drives: 2010 SS2 RS Inferno Orange
There's a TSB for this.. They add washers and replace 2 nuts.. That's the fix
BruceJames is offline   Reply With Quote
Old 06-01-2010, 12:04 PM   #12
SS Mike
SS Mike's Avatar
There's a TSB for what exactly? The same thing as described above? The axle housing issue? Thanks.
Old 06-03-2010, 02:40 AM   #13
Dameon
Drives: 2010 Camaro 2SS
I have the same sound in mine. I brought it in the end of last year and was told that there was nothing wrong with it. Time to bring it back and tell them exactly what to check out.
Dameon is offline   Reply With Quote
Old 06-03-2010, 02:47 PM   #14
Holis
Drives: 2014 2SS Convertible
I hear a clicking once in a while as well, not sure where it is coming from
Holis is offline   Reply With Quote
GMPP Exhaust (Axle Back) Sound Video Clip SS_in_Black Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 84 05-30-2011 12:08 AM
Exhaust sound bulldog Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-07-2009 03:43 PM
Pricing Speculation of the 5th gen - (not actual) CamaroSpike23 Camaro Price | Ordering | Tracking | Dealers Discussions 281 01-17-2009 07:22 PM
Independent Rear Suspension? steveo42 Wheels and Tires Talk Sponsored by The Tire Rack 35 05-22-2008 06:58 PM
Pricing/optioning guesstimate KILLER74Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 156 02-24-2008 05:33 PM
