Old 12-22-2016, 06:07 PM   #1
d00mz
Drives: 2020 Camaro ZL1 Convertible
Convertible front molding
Gang,
I need to replace the interior front molding on my 2014 ZL1 convertible. I've found the part on GM Parts direct 22766899 - but I can't tell how to remove the old one.
See item #2 in the attached image.
Does anyone have any experience with removal/replacement of this part?
-d00mz
2020 ZL1 Convertible in Shock
-Bone stock (for now)
2017 ZL1 Convertible in Hyper Metallic Blue (sold)
-stock
2014 ZL1 Convertible in Red Hot (sold)
-Roto Fab Cold Air Intake with larger HX Rez
-2.5inch upper pulley, solid isolator
-Ported Blower Snout
-ARH 2 inch headers and longflow off-road pipes
-1000cc fuel injectors
-NGK TR71X plugs
-Catch Can
-Dyno tuned to 600RWHP
-All work done by Advanced Modern Performance
d00mz is offline   Reply With Quote
Old 12-22-2016, 08:59 PM   #2
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
I don't know if I would recommend doing that yourself - you have to peel back the convertible top fabric. The screws that hold the trim part on shoot straight down.
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 12-22-2016, 10:12 PM   #3
d00mz
That's the entire issue. Two of the tabs that the screws go into over the driver side are broken. It rattles like a mofo.
-d00mz
-stock
-NGK TR71X plugs
-Catch Can
Old 04-30-2018, 12:04 AM   #4
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Drives: 2015 2SS/RS CV CE
https://www.camaro5.com/forums/showthread.php?t=450321
PDXSSCE is offline   Reply With Quote
Old 05-22-2023, 02:17 AM   #5
Bilhickok
Drives: 2014 2ss camaro convertible
Cool Repair convertible front plastic trim
Like many things I've suffered with in my Corvettes and Camaros over the years, the design of the trim piece is obviously flimsy and flawed, and replacement only sets you up for a frustrating identical repeat problem in the future.
Has anyone attempted to re-attach the plastic bosses with crazy glue and baking soda combination? It supposedly forms a rock solid bond to plastic
I will be trying it on my 2014 2SS convertible soon and will post the results.
So far no problems with the 22 ZL1, but time will tell.
Bilhickok is offline   Reply With Quote
Old 05-22-2023, 10:01 AM   #6
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
I'm not sure if this is in other areas of the forums because the search feature sucks donkey ballz. But here's a video of what it takes to take apart the top to get the trim piece off. Repair or replace, that's an option left to you. But it doesn't look too difficult.
https://youtu.be/lAqMBYLJHf4
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 06-11-2023, 02:06 AM   #7
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Old 06-18-2023, 09:03 AM   #8
Geezerss
Geezerss
Geezerss's Avatar
Drives: 2011 ss2 droptop red/blkst hckyst
I purchased the part , but haven't installed it yet. I ihave a 2011 soft top. this u tube is for a 2012 soft top. don't know how much different it would be for a 2020.
The only reason i can see it breaking is driving without the cover on and the top flaps in the hole
good luck
Geezerss is offline   Reply With Quote
Old 06-18-2023, 09:04 AM   #9
Geezerss
Geezerss
Geezerss's Avatar
Cool
good luck
Old 06-18-2023, 09:39 PM   #10
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
good luck
My presumption has been that they break when closing the top and allowing it to drop onto the top of the windshield. It hits sorta hard.
I let it drop onto my hand and then ease it down.
Old 06-20-2023, 09:03 AM   #11
el ess A
Older Than Dirt
el ess A's Avatar
I just checked the mileage on the ZL1 and it's 2,887. I thought I'd already gone over 3K by now. Hmmm. Nothing is broken...yet.
And yes, I too, do not let the top slam down on the windshield. I bring it in close, grab the handle, then guide it down the rest of the way very slowly.
But I did purchase a new piece of front trim anyway to stash in the corner because if/when it ever happens, I won't be wishing I'd have bought one when they were still cheap and available. And the bonus is, if I end up getting rid of the car without using it, I can just sell it later. I know people will buy it. Because those interested in it actually would be needing it.
I don't wear driving gloves when I drive it, so I've already purchased new alcantarra shifter knob, boot, and steering wheel almost 10 years ago. I see those as high-wear parts. I keep them clean, but eventually that stuff's going to wear off. Again, they'll be highly desireable parts for those that need them one day, even if I don't.
Old 06-22-2023, 12:44 AM   #12
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
But I did purchase a new piece of front trim anyway to stash in the corner...
What's the part number please?
Old 06-22-2023, 07:46 AM   #13
el ess A
Older Than Dirt
el ess A's Avatar
22766899
This is for the 2011-2015 5th gens. I don't know if it would fit the 6th gens, but I doubt it.
Old 06-22-2023, 10:30 AM   #14
el ess A
Older Than Dirt
el ess A's Avatar
Additionally, the price has about doubled or more in the last few years, so might want to get them while you can.
