Old 10-18-2009, 07:01 PM   #1
markssylver
Drives: 95 bbb impala ss
tpms sensors
when replacing the tpms sensors how do you pair them up to the car my wheels got stolen 2 weeks ago and i went and bought new tires wheels annd tpms sensors i had the wheels put on and did the relearn through the dic but dont think they are reading correctly all of them say 32 do i have to go to the dealer to get them programmed?
markssylver is offline   Reply With Quote
Old 10-18-2009, 07:08 PM   #2
JusticePete
Drives: Camaro Justice
Use the old style method where you bleed down the air pressure until it trips a warning.
Old 10-18-2009, 07:08 PM   #3
fastal
Drives: 2010 2SS/RS, 2000 Z28
Follow the directions in the manual worked for me, though it took me 3 tries. I got a set of 18" wheels with snow tires and new sensors. If the car didn't pick up the sensors after you did the relearn you would have a - in place of the numbers.
fastal is offline   Reply With Quote
Old 10-18-2009, 07:21 PM   #4
JusticePete
Much depends on rim depth. My sensors are so far in we picked up the car next to us, nothing and when we thought we had it right the Camaro got confused in my garage and screwed up both the Camaro and G8 TPM systems requiring both be reprogrammed back at Witt Buick. If the new wheels have deeper rims extra care may be required to associate the TPM sensors.
Old 10-20-2009, 09:49 PM   #5
JusticePete
Did you get them to work?
Old 10-20-2009, 11:05 PM   #6
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
I did this yesterday with 2 new front wheels. Very easy procedure. Just follow the manual. Did it the 1st time and it worked fine.
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 10-21-2009, 06:45 AM   #7
55Designs
Drives: 2010
Is there a way to disable TPM?
Cost on these sensors by the way?
55Designs is offline   Reply With Quote
Old 10-21-2009, 07:43 AM   #8
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
The TPMS sensors ran me about $57.00 each. www.tirerack.com
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Old 10-21-2009, 01:28 PM   #9
JusticePete
If you turn them off I am not ure if it impacts any of the other systems (abs, stability, traction, etc...). Maybe a GM ASE or an HP Tuners person can chime in.
Old 10-21-2009, 01:37 PM   #10
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
My 2 rear sensors are all screwed up. Left reads 30 right reads 41. I have 36 in all 4 and check it manually. I just ignore them now.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 10-22-2009, 09:02 PM   #11
markssylver
i did get them to work i never found in the manual where is says how to do it i just put it in relearn mode then started letting air out of each tire until the horn would blow once all 4 were done i refilled the tires then chcked with a hand gauge and the cars gauge was spot on not like my origional tires that read one thing and the car said something else
Old 10-23-2009, 08:11 AM   #12
JusticePete
Doc and you are both correct. There is an update, but that didn't work with my deep set wheels. The bleed down did work. It will depend on the location of the sensor in terms of how deep it is behind the wheel center.
Old 10-24-2009, 12:23 PM   #13
Teddydog
Teddydog's Avatar
Drives: 21 LT1 RS M6 in SSM
What order did you do them in? That's how the computer knows which one is which. When you start the relearn process, it "listens" first for the driver's front tire and learns it, then you do passenger front, then passenger rear and finally driver's rear. If you did a different order, then it thinks your tires are in different places on the car. According to the manual, you have 5 minutes to get the first one and 2 minutes for the others with a total time limit of 10 minutes.
When I put a set of factory 19" wheels & tires on my 2LT RS, I had to relearn the sensors. Some took a lot of airing-out before the horn honked (passenger rear) and some were almost right away (passenger front and driver rear).
Rob
Teddydog is offline   Reply With Quote
Old 10-24-2009, 02:05 PM   #14
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
Just installed 20 inch forged CCW wheels, 10" wide front and 11" in back. Pirelli 275's and 305's in back. CCW made the wheels using the future Z-28 offsets. There is no rubbing or sticking out of the fender lip. I did the owners manual relearn procedure in about two minutes total. You only need to let out 2 to 3 psi for it to learn which tire to recognize. Going clockwise from front left first is very important.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
TPMS Question mfeeney85 Wheels and Tires Talk Sponsored by The Tire Rack 2 11-22-2009 06:04 PM
TPMS sensors question Teddydog Wheels and Tires Talk Sponsored by The Tire Rack 2 09-25-2009 08:40 PM
AFTERMARKET WHEELS AND TPMS dnr427 Wheels and Tires Talk Sponsored by The Tire Rack 6 07-09-2009 11:35 PM
TPMS SENSORS hot ss Wheels and Tires Talk Sponsored by The Tire Rack 2 07-06-2009 01:57 AM
