![]() Drives: 2015 2SS 1LE Join Date: Feb 2016
SP Headers - Removing the Steering Shaft
I am going to install a set of Stainless Power LT Headers on my 2015 SS/1LE this weekend. The directions on the Stainless website say to remove the steering shaft. I have been told that this is not a necessary step. I'd rather not mess with the steering shaft if I don't have to. Can anyone give some advice about whether or not I need to remove it or can the headers be easily installed without disconnecting the steering?
![]() Drives: 2012 Ashen Gray LS3 M6 (SOLD) Join Date: Oct 2014
Correct as long as you have a good lift you can install without removing
2012 Camaro SS/RS LS3 6Spd (SOLD)
2011 Camaro RS 6 Spd (SOLD) 2007 Subaru WRX STI (SOLD) 1997 C5 LS1 Corvette (SOLD) 1985 C4 L98 Corvette (SOLD) 1967 Camaro RS/SS 383 sb (STOLEN) |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I never touched my steering shaft and installed my headers off the back of a trailer. Took the center wood out and drove up the back. You shouldn't have to remove the steering shaft as there should be plenty of room. Some headers need to be dimpled because of their close proximity to the shaft. Keep this in mind and verify if needed before completly installing.
More to come. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 Join Date: Oct 2015
I installed my stainless works headers without disconnecting the steering shaft. I had a lift, but I would think it's still possible with a good set of taller jack stands too.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
I didn't have to bother with the steering shaft for my headers either.
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
#6 |
Thanks guys for the responses !!
#7 |
![]() Drives: 2011 Camaro 2SS/RS L99 Join Date: Aug 2013
I disconnected mine, its easy to do then put back together, installed on jack stands
![]() Stainless Power Headers, High Flow Cats, CAI intake, SLP Loudmouth 1 exhaust, Dyno tune from Alternative Performance |
#8 |
![]() Drives: 2015 Camaro SS convertible L99 Join Date: Nov 2016
I did mine without removing the shaft. You might need to adjust the engine mounts so that the headers do not touch the shaft.
#9 |
Keeper of THE list
I removed mine because the shorty headers that were on the car when I bought it required the steering shaft to be removed to remove them. It's one bolt and you can slide the shaft up towards the steering wheel. If you do remove the shaft make sure your steering wheel is pointed straight and not cocked at all. Otherwise it can be a pain to get back together.
#10 |
![]() Drives: 2018 camaro 1ss 1LE Join Date: Apr 2013
just installed my headers yesterday. you dont need to remove it at all. maybe the dip stick thats about it. i would suggest using your oem gaskets tho. the ones i got were garbage.
#11 |
I had to undo mine because I put the headers on using rhino ramps. If you get the front end high enough you shouldn't have to undo it.
2013 VR Camaro 2SS/RS LS3
Small, but effective mod list: Roto-Fab Intake, TSP 2" Long tubes, TSP catless mids, MSD spark plug wires, stock catback, Elite Catch Can, APEX washer relocation and scoop, VMAX throttle body, Diablo InTune-Tuned by Matt@FSP, and a JacFab license plate bracket. |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
I didn't disconnect mine
Sent from my iPad using Tapatalk
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#13 |
Love me some Tacos
I have no idea until saturday.
#14 |
Hopefully you have hi flow cats and the stainless works retro chambered exhaust!
Setup without either is very raspy, but with cats and retro chambered exhaust it's very deep at all rpms unlike other exhausts I've heard with long tubes
