Old 01-22-2017, 07:07 PM   #1
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
OverKill 80mm Throttle Body
Finally got around to installing mine this weekend. Happy with quality and fitment. Super easy install that takes about 20 mins.
Question I have for you guys:
I'm noticing a whistling type noise that seems like it's coming from my CAI now. Specially around 2k rpms. When I step on it, it goes away but if I feather the pedal I can pretty much get it to do it constantly.
I've put about 2 hundred miles on car since install and this hasn't changed. Almost sounds like there is an air leak or seal issue etc.
Anyone else experience this? Is it normal?
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 01-22-2017, 07:13 PM   #2
Kenny Camaro
Drives: 2013 1LT RS Camaro
No, never had that experience.
Kenny Camaro is offline   Reply With Quote
Old 01-22-2017, 07:17 PM   #3
sspade
sspade's Avatar
Hm. Weird. Hopefully someone with the CAI brand intake can chime in. Worst case, I'll take it apart and reinstall next weekend.
I don't understand what I could have done wrong. Was sure to make sure everything was snug and good contact with intake box etc.
Old 01-22-2017, 09:26 PM   #4
BluedEvil21
BluedEvil21's Avatar
Drives: 2013 Camaro v6 hot wheels edition
If you don't have a check engine light shouldn't be an issue...my engine whistles on accelerating sometimes though I don't have the same set up
Drop a gear and disappear
BluedEvil21 is offline   Reply With Quote
Old 01-22-2017, 09:35 PM   #5
sspade
sspade's Avatar
No lights whatsoever on dash...
Old 01-22-2017, 09:37 PM   #6
VanillaE
Drives: Black 2010 Camaro SS
Porting an 80 mm
So I have the ported intake manifold and spacer as well 80mm tb. What would porting the 80mm offer ? And is there anyone that could do it ? Or is it easy enough I could do it ?
VanillaE is offline   Reply With Quote
Old 01-22-2017, 09:38 PM   #7
VanillaE
I had that experience the first time I installed it without using a gasket . Two days later I reinstalled and created the gasket and no problem ever since then
Old 01-23-2017, 12:05 AM   #8
derek1387
Drives: 2015 1LS Red V6
Your TB is already bigger than the port on the ported manifold.
You would want to port the manifold out to match the TB.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 01-23-2017, 07:01 AM   #9
VanillaE
When he ported my manifold he ported it to match a 80 mm tb
Old 01-23-2017, 08:22 AM   #10
derek1387
Then I wouldn't bother doing any more.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 01-23-2017, 09:11 AM   #11
sspade
sspade's Avatar
What gasket are you referring to?
I have the newest model of the OverKill TB - It does not require using liquid gasket and has a built in gasket.
The stock gasket in the end of the manifold seals against the adapter plate supplied with TB and then the TB itself has a built in gasket that seals against the plate.
I guess I can try cranking both sets of bolts down further. I only tightened them with an allen key and snugged them pretty good with the "ol wrist torque wrench"
Im pretty sure instructions stated not to over tighten....
Anyone else please share your thoughts on what Im experiencing...
Old 01-23-2017, 10:51 AM   #12
derek1387
The original setup didn't have a gasket or oring groove machined into the adapter. That's what I'm assuming he is referring to. Will has made some changes based on my recommendations since originally coming out with the kit.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 01-23-2017, 01:15 PM   #13
sspade
sspade's Avatar
That's what Im thinking also.
Sssooo... What would you recommend. Does what I describe seem normal?
Would you take apart and crank the bolts down tighter? I kind of seems like its coming from the CAI (from drivers side corner of engine bay) but its hard to tell...
Old 01-23-2017, 01:40 PM   #14
Mikeiser
Drives: 2015 Colorado v6 LFX
I hear the exact same thing after installing on my Colorado. I really don't think its actually an issue. It happens with barely any throttle applied at any speed, which leads me to believe its the sound of air rushing past a near-closed TB. On the OEM TB, you couldn't hear it because of the immediate turbulence created right after the TB. Now, you have a perfect transition where the air flows smooth, past the edge of the butterfly valve, like a whistle.
Mikeiser is offline   Reply With Quote
