Old 01-23-2017, 05:19 AM   #1
BluedEvil21
BluedEvil21's Avatar
Drives: 2013 Camaro v6 hot wheels edition
2015 canyon manifold
So I was just surfing the Web and came across a picture of a Chevy canyon 2015 manifold and the bolt pattern looks like it would bolt to the lfx... it clearly is different up top, but was wondering if anyone else has noticed this and would have any info on if it is a better or worse manifold then the one we have now...has anyone done this? Does it even match? I could just be over tired lol
Drop a gear and disappear
BluedEvil21 is offline   Reply With Quote
Old 01-23-2017, 05:27 AM   #2
BluedEvil21
Here's the intake
Old 01-23-2017, 10:08 AM   #3
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
Hm. Interesting.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 01-23-2017, 01:43 PM   #4
Mikeiser
Drives: 2015 Colorado v6 LFX
For what its worth, its still the LFX engine... I'd be more concerned if it'd fit under the hood (it probably will).
Mikeiser is offline   Reply With Quote
Old 01-23-2017, 02:43 PM   #5
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Right out of the box, the canyon/colorado manifold flows about 10% better than the stock Camaro intake manifold. It will bolt onto the engine, but I don't know if the hood will close, and you would have to redo the intake piping from the TB to the airbox as your stock, or aftermarket CAI stuff will not bolt right up to it as well as the PCV lines won't hook right up either.
Jason@JacFab is offline   Reply With Quote
Old 01-23-2017, 03:52 PM   #6
gringo
gringo's Avatar
Drives: Camaro V6
It makes me wonder why GM made the intake flow 10% better on the Canyon/Colorado twins compared to the Camaro.
If anything, you would think the low to mid range torque requirement would be a priority (since they are trucks) while the Camaro would get the 10% better flowing intake for higher peak HP numbers.
gringo is offline   Reply With Quote
Old 01-23-2017, 03:56 PM   #7
Jason@JacFab
It probably had more to do with fitment/packaging than performance.
Old 01-23-2017, 06:17 PM   #8
Kenny Camaro
Drives: 2013 1LT RS Camaro
10 percent, that's huge. How much are they costing and where can you pick one up? Boneyard? Dealership? Would the ecu 'self learn' and adjust to that increased flow, or is that too much of a change?
Kenny Camaro is offline   Reply With Quote
Old 01-24-2017, 04:09 AM   #9
Kenny Camaro
Any info would be appreciated, thanks!! With 10% better flow and an 11.4% bigger TB in the Overkill 80mm TB, this could be a very worthwhile mod. Any thoughts?
Old 01-24-2017, 07:34 AM   #10
BluedEvil21
Thanks for the responses guy's...I may have a new project now I think stretching pvc lines and harnesses won't be that bad of a challenge...10% more without a port may be worth it
Old 01-24-2017, 07:47 AM   #11
BluedEvil21
Well forum I just scored one from ebay for $126. An FYI any 3.6l 2015 manifold is the same as the Colorado or canyon I'll be hopefully getting it soon... and I'll have more info for you guys...thank for the input so far
Old 01-24-2017, 11:02 AM   #12
Jason@JacFab
For comparison, my ported intakes flow 20-21% better than stock (10-11% better than the Colorado intake, which is why I never bothered to try one because it would have been a lot of extra work to make the rest of the stuff I mentioned above fit.
You also have to remember that the engine or ecm isn't seeing the whole 10-20% airflow increase. I test the intakes with a throttle body only on the flow bench. So if you were to test a cylinder head through the intake valves open at max lift, with the intake pieces, throttle body, CAI of your choice with air filter, you'd likely only see a 2-3% change all together as a whole system, so yes, the ecm can compensate. I only flow the intakes by themselves to test consistency of the porting.
I don't think the Colorado intake would be worth the effort and extra cost to make it work. You'll probably spend just as much or more than me porting an intake for you by the time it's all said and done.
Old 01-24-2017, 11:54 AM   #13
BluedEvil21
It's just something to mess with still going to port my original intake as I have a 80mm tb to install from a junkyard too.
Old 01-24-2017, 01:39 PM   #14
sspade
sspade's Avatar
Jason - How long approximately will a stock intake need to be in your possession before you turn around and send back?
