Old 10-21-2009, 07:50 PM   #1
ssmike
BL1ZZRD
ssmike's Avatar
Doug Thorley shorties install questions
Anyone who has installed Doug Thorley shorties I have some questions.
1) Do they install from above or below. If below, how high do you have to jack the front end up?
2) Do you have to remove the cats like the instructions say to do?
3) How long does it take?
4) Any issues with alignment to the cat flanges?
Thanks!
Old 10-21-2009, 08:05 PM   #2
BITCHIN CAMARO
BITCHIN CAMARO's Avatar
Drives: 2010 Camaro RS SS
Driver above, Passenger side below.
No need to remove the cats or the wires that go to the sensors. Just loosen the bolts that hold them on.
Use a floor jack and jack up high enough to get the header in.
Took 1.5 hrs
Don't remeber any alignment issues to the cat flanges
BITCHIN CAMARO is offline   Reply With Quote
Old 10-21-2009, 09:47 PM   #3
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
I encountered alignment issues with the cat flange on the driver-side. 'Had to take it to my exhaust shop and have the guy heat it up with the welding torch to line them up (at least he didn't charge me). Mine must have just had a glitch with the alignment, as I haven't heard of anyone else with that issue. I don't know how it took these guys 1.5-3 hours to do the swap. It took me and bobby35ny 9 hours to do mine and we weren't goofing around. I guess it was because it was hard to get around without a good lift and just a jack and we had trouble getting the stock passenger-side manifold out. Don't let it deter you though. I'm pretty happy with the performance now that everything's aligned correctly.
fldrummer is offline   Reply With Quote
Old 10-21-2009, 10:31 PM   #4
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
Took me about 5 hours. Had to remove the cats in order to remove from the bottom. The instructions say to remove the manifold and cats as 1 piece. I found it easier to unbolt at the flange that connects the cats to the manifold. There's a couple of manifold bolts that require slow going with a wrench. The only thing I didn't like was that they don't come with new gaskets. Overall not that bad, and love the headers.
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 10-22-2009, 01:00 AM   #5
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Yah, WTF?
HeavyD is offline   Reply With Quote
Old 10-22-2009, 05:14 PM   #6
ssmike
BL1ZZRD
ssmike's Avatar
Did you re-use the old gaskets or get new ones?
Old 10-22-2009, 06:23 PM   #7
The Leaf
The Leaf's Avatar
Drives: 2010 Camaro SS
they said to re-use the stock gaskets, but i bought a new set from gm and used them they were about $13 each, this will have been the 4th car ive put a set of headers on and i cant see reusing gaskets even if they are metal.
The Leaf is offline   Reply With Quote
Old 10-24-2009, 08:33 AM   #8
ssmike
BL1ZZRD
ssmike's Avatar
I did the install last night, took about 5 hours total! Driver's side I did alone in about 1 1/2 hours and installed from the topside. The passenger side I had help with and took about 3 1/2 hours. All went well and I thank all of you for your advise and suggestions. Now today I'll take her out for a spirited romp to see how they sound and perform! All in all the install went fairly smooth, just tough to get some of the manifold bolts out and had a little trouble lining everything up. Definatly a 2 man project.
Old 10-24-2009, 09:43 AM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Cool! Please report back with a butt-o-meter assessment and if there was much improvement in sound
'20 ZL1 Black "Fury"
Old 10-24-2009, 09:58 AM   #10
HeavyD
HeavyD's Avatar
Anyone removing the spark plugs?
Old 10-24-2009, 11:11 AM   #11
Icntdrv55
CCOTR Member
Icntdrv55's Avatar
Drives: Victory Red 2010 2SS/RS A6
So can you tell the differance in the ol butt dyno? I am thinking of putting a set on as well but want to know if they are worth it or not! I wouldnt expect to see or feel a huge differance but you should feel something !
Camaro Club Of The Rockies (CCOTR) Check us out on Facebook!
2010 Camaro SS/RS Victory Red A6- Vararam Intake, Doug Thorley Tri Y LTs, Magnaflow X-pipe, Flowmaster Super 40's, VMS Tune, Razzi Ground Effects, Herritage Grill, RED headlight and fog light Halos, LED DRLs, Dash and extended Door ABL, engine, grill and rear defusser LED lighting ........ 12.59@112.21 (DA Corrected)
Icntdrv55 is offline   Reply With Quote
Old 10-24-2009, 11:35 AM   #12
The Leaf
The Leaf's Avatar
I removed the spark plugs only the passenger side cuz i thought it was easier to work the header into posittion...
Old 10-24-2009, 03:36 PM   #13
Cooper2010
Cooper2010's Avatar
Drives: 2010 LS3 2SS CGM
1. When removing the oil dipstick tube do you also need to drain the oil?
2. Did anyone have any trouble with wirings coming close to the headers (Need to use zip ties to put them in better position)?
3. Does the stock header shielding fit over these? If so would it make any difference?
Thanks for the help!
CGM 2SS LS3
Cooper2010 is offline   Reply With Quote
Old 10-24-2009, 05:22 PM   #14
ssmike
BL1ZZRD
ssmike's Avatar
No for all 3
Doug Thorley Shorty Headers :: +20rwhp, +35rwtq! Sean@Phastek V8 Bolt-Ons & Tunes 67 01-20-2014 08:25 PM
Doug Thorley Shorty Headers for 2010 Camaro Installed -WOW! Rallyman6 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 64 03-13-2011 12:36 PM
Doug Thorley Shorties/Custom X-pipe/Flowmaster Super 44s with VIDEO Edrock Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 09-24-2009 09:24 PM
Doug Thorley cat-back installed!! SS Mike Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 09-05-2009 03:34 PM
Doug Thorley Shorties w/ GMPP Mufflers (video) Rallyman6 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 07-23-2009 08:25 PM
