Old 02-19-2017, 11:41 AM   #1
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Front suspension, tools needed?
Can anyone tell me what size the nuts are on the front struts? I'm guessing around 24MM. Picture included for reference.
Also, please add any other tools that will be helpful or needed for front end suspension work. Thanks!
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 02-19-2017, 11:44 AM   #2
OmniCamaro
US Veteran
OmniCamaro's Avatar
Sorry for the ginormous picture!!! Not idea how to fix it on a MAC.
Switched to my iPad and used Tapatalk. Much easier for posting pic's.
Old 02-19-2017, 12:45 PM   #3
Synner
Drives: cars
Most everything is 19 or 21 on the front. Those should be 21.
Old 02-19-2017, 12:59 PM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Or 7/8 if I remember correctly.
Orange Krush II
Old 02-19-2017, 01:36 PM   #5
Fondue Wormhole
Bad Example
Drives: Camaro SS
A couple easy ways:
1) Open with Preview, Select Tools -> Adjust Size. In the 'Fit Into' drop down menu (Custom), select either 640 x 480, or 800 x 600.
Click 'OK', then 'File' -> 'Save' (or Quit Preview and click 'Save').
To Rotate the image: 'Tools' -> 'Rotate Right' or 'Rotate Left'
To Crop: Select the area you want to keep by dragging your mouse (Click & Hold) over it, then Tools -> Crop
2) Use a free web hosting service which will have an option to re-size the image. Again, select 640 x 480, or 800 x 600.
Copy the Url for 'Forums / Message Boards' and paste it in your post.
BTW, if you didn't remove the Wheel Speed Sensor cable from the tab on the strut, you should reinstall it, or be sure to reinstall it when your done.
Fondue Wormhole is offline   Reply With Quote
Old 02-19-2017, 03:39 PM   #6
OmniCamaro
US Veteran
OmniCamaro's Avatar
Originally Posted by Fondue Wormhole View Post
A couple easy ways:
Thanks!
This is a pre-work photo.
Old 02-19-2017, 03:40 PM   #7
OmniCamaro
US Veteran
OmniCamaro's Avatar
24MM for the bolts that hold the strut to the spindle. Just verified it.
I have the sizes you mention, just not one this big. Had to make a run to the tool store and they easily got $100 from me, lol.
Old 02-19-2017, 07:11 PM   #8
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
15/16th or 24mm. I just removed mine to install coil overs and used 15/16th.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 02-19-2017, 07:21 PM   #9
OmniCamaro
US Veteran
OmniCamaro's Avatar
I didn't even think there were any SAE sizes on cars anymore. Good to know, thanks.
Old 02-22-2017, 05:44 PM   #10
OmniCamaro
US Veteran
OmniCamaro's Avatar
Started removing things today.
Got both side strut to knuckle bolts loose (those were TIGHT). Glad I bought that breaker bar! When I got these loose the strut moved around quite a bit. Did I mess up by not marking anything before loosening these?
Removed the strut to sway bar links. On both upper sides I had to hold the center of the bolt that sticks out with vice grips(see pic, circled). That sucked!
Comparing those with the new ones there's a huge difference (see pic).
Still waiting for my struts to get back from the painter and will be removing the sway bar tomorrow. That should be fun.
Sent from my iPad using Tapatalk
Old 02-22-2017, 06:23 PM   #11
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Yes your camber will have to be reset by an alignment shop.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 02-22-2017, 06:52 PM   #12
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
You used a vice grip on a hex ended bolt?
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 02-22-2017, 09:41 PM   #13
OmniCamaro
US Veteran
OmniCamaro's Avatar
Yes. I knew I was throwing it out plus I don't have hex sockets or wrenches. For whatever reason the top ones were a PITA all the way out to the end. The bottom ones came right off.
Old 02-22-2017, 09:41 PM   #14
OmniCamaro
US Veteran
OmniCamaro's Avatar
Ok cool. That visit will happen no matter what.
