Old 10-22-2009, 01:59 PM   #1
PaycekZ28
Drives: Dly- '05 TSX Grg- '97 Z28
No 1st gear on 4th Gen auto!?
I have a '97 Z28 auto, and I only have 2nd through OD. What gives? I've owned the car for over a decade and still have no idea why no 1st. Any info would be awesome, thanks!
PaycekZ28 is offline   Reply With Quote
Old 10-24-2009, 10:04 PM   #2
nemosgt
Drives: 2006 Ford Mustang GT
Send a message via ICQ to nemosgt
You probably just can't select first gear with the lever. I'm pretty sure in "drive" the tranmission does go into first when you come to a stop or start out.
Cheers.
nemosgt is offline   Reply With Quote
Old 10-26-2009, 12:57 PM   #3
PaycekZ28
Yeah, just can't select 1st, wondering if anyone knew why Chevy did that. Thanks though.
Old 10-26-2009, 03:52 PM   #4
Tim@HPE
Drives: 4th Gen Camaro
You have 2.73 gears in the car. These cars only had 2,D,OD on the gear selector.
The 3.23-geared autos have 1,2,D,OD. This was the "performance axle" option (code GU5 located on the sticker in the glovebox or on the inside of the door, depending on the year). Don't remember the code for the 2.73 off the top of my head.
Not 100% sure, but I remember hearing there's some sort of block-off plate and all you have to do is pop off your center console cover, remove it and then you can manually select 1st.
Tim@HPE is offline   Reply With Quote
Old 10-26-2009, 04:02 PM   #5
toehead93
Drives: 2014 2SS/1LE
Tim beat me to it, he is dead on.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 10-26-2009, 04:11 PM   #6
nemosgt
First gear is pretty steep. The average person might complain if they downshifted and found the car standing on its nose from the engine braking; whereas with the performance rear-end, enthusiasts wouldn't care.
Try starting out with second selected; I bet you will get a one two/upshift.
Cheers.
Old 10-27-2009, 01:13 PM   #7
PaycekZ28
Awesome! Thanks guys! Now I know...
Old 10-27-2009, 01:28 PM   #8
S8ER01Z
Drives: Camaro Z28
The 1st gear selector is missing on 2.73 gear cars because they wouldn't pass a certain inspection (noise or emmissions I can't remember which)... the car would carry high rpms at the testing mph used and they had to prevent it. You can pop the center console selector off and file away the plastic tab that prevents the downshift from occuring (or find a center console from a 3.23 geared car).
S8ER01Z is offline   Reply With Quote
Old 10-29-2009, 05:36 AM   #9
fbodyrs96
fbodyrs96's Avatar
Drives: 1996 Camaro RS convertible
GU2
This is the standard axle ratio for an automatic Z28. The ratio is 2.73.
With this axle ratio, you do not have 1st gear as a selectable option on your shift plate.
This is due to federal noise pollution regulations GM had to conform to. Cars with RPO GU5 have 1st gear, because their 3.23 ratio made 1st gear impossible to select. Why? Because the speed was too high for a 3.23 Z28 to run in 1st gear, but not too high for a 2.73 Z28 to run. The 2.73 Z28s would be too loud (high in RPM) to pass the test in first gear, so GM had to restrict it.
I don't remember the 4-speed automatic gear ratios off the top of my head, so I can't tell you what speed the test was testing, but I would "assume" it was 45 mph. 3.23 axle would likely cause the max speed in 1st to be closer to 40, while 2.73 would likely cause the max speed in 1st to be closer to 50. I need somebody to do the math...
fbodyrs96 is offline   Reply With Quote
Old 10-29-2009, 09:11 AM   #10
S8ER01Z
Drives: Camaro Z28
Originally Posted by fbodyrs96 View Post
GU2
Well apparently it's down at the moment... but when it comes back up this is what I use as a go-to.
http://f-body.org/gears
If that's not up you can use this until they purge it.
http://web.archive.org/web/200804201...ody.org/gears/
Old 10-29-2009, 10:43 AM   #11
PaycekZ28
Sweeeet thanks man!
Old 11-03-2009, 09:46 AM   #12
PaycekZ28
Yay!!! I can select 1st gear now!!! Sawed off "1st gear selecter blocker(?)" last night.
Old 11-03-2009, 09:52 AM   #13
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
nice. what was your purpose for needing to select 1st gear?
I piss excellence
and fart awesomeness
Old 11-03-2009, 11:39 AM   #14
HorsePowerAddicts
HorsePowerAddicts's Avatar
Drives: LSx Powered
Holding it in first while driving around will just heat the trans up. Its best to leave the car in drive and have your shift points set to match your setup.
HorsePowerAddicts is offline   Reply With Quote
1st Gen Camaro Owners raise your hands Trevor ruffcorn 1st & 2nd Generation Camaros 451 01-18-2014 05:45 PM
5th gen or 1st gen that is the question... gold5000000 5th Gen Camaro SS LS LT General Discussions 73 10-14-2009 02:57 AM
4th Gen 1/4 mile times versus 5th Gen 1/4 mile times Rock36 Dragstrip and Launch Techniques Discussion 52 07-29-2009 11:01 PM
Consensus Feb 6th Plus lots of other key dates UCF w00t 5th Gen Camaro SS LS LT General Discussions 16 01-23-2009 12:39 AM
