Old 03-06-2017, 10:43 AM   #1
Ace0751
GEN5 Detail
Ace0751's Avatar
Drives: 2011 Synergy Series 2SS Convertible
BMR Lowering Spring w/ ACS T4 Splitter Clearance
Have a question, does anyone run BMR 1.25 lowering springs with a ACS T4 splitter? Would like to know how the clearance is from the ground. Have a nice deal for these springs that I may purchase and would like to get some feedback on the clearance. I also picked up the new Michelin pilot 4s tires 275/35 front and 295/30 rear which is another reason why I am looking at these so I can fill that gap in the wheel well. Plus my driveway has an angled curb which means if fly over it I'll scrape the splitter easily.
Any feedback would be much appreciated.
Roto-Fab CAI, Borla ATAK Exhaust System, Stainless Power Headers, RX Performance Catch Can, ACS T4 Splitter, Oracle side markers, Dyno Tuned by RDP Motorsports
Ace0751 is offline   Reply With Quote
Old 03-06-2017, 11:13 AM   #2
dentnshell
dentnshell's Avatar
Drives: Black 2014 2SS
I run the 1" Lowering springs.
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.)
dentnshell is offline   Reply With Quote
Old 03-06-2017, 11:20 AM   #3
dentnshell
dentnshell's Avatar
Again 1" BMR Springs
Does it sit lower yes... Does the front splitter stick forward a bit... Yes. Does it make inclined transitions difficult yes.... Is it worth it???
I think it looks great. I am glad I didn't do the 1.25 inch. I think the 1" has been perfect, not to mention my rear driveshaft angles stayed more in-line. I can still align inside of factory specs without other suspension parts.
If you like to jack the front up with a single jack, you will need to drive up on 2x4's or something first, just to get the low profile jack under the front.... I now have race ramps. Make sure you get the 6.6degree approach.
Old 03-06-2017, 11:28 AM   #4
Ace0751
GEN5 Detail
Ace0751's Avatar
That might actually might be the way to go, only lower it about an inch. Forgot to mention that I have the factory gfx package also. 1.25 may lower it too much but any other feedback will be helpful.
Old 03-06-2017, 11:42 AM   #5
dentnshell
dentnshell's Avatar
The only issue is really that front point, you know the type of roads your normally drive on. The car is my wife's daily driver, she is extremely careful and does her best to pay attention to entrance's and exit's. She scraped the front tip the other day leaving a parking lot to get to the road. You are only talking about a 1/4" lower... But at some point there is a limit. We do have the extra weight of the LSA in the front and the extra weight of the ZL1 rear diff in the back. Not sure if that squats her down a 1/4" but it is worth noting and may have the car a little lower than a typical 1" drop.
FWIW those pictures were taken before both of those mods.
Old 03-06-2017, 11:48 AM   #6
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
I've got the Ebay knockoff of that splitter with 1" BMR lowering springs.
It's perfect, IMO. It's a good aggressive look, great handling, and I can still make it up my driveway.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 03-06-2017, 12:05 PM   #7
Ace0751
GEN5 Detail
Ace0751's Avatar
Thanks for some feedback, I'm looking at the eibach and bmr 1" springs. Wonder if the stock springs are the same on both the coupe and vert.
Old 03-06-2017, 12:31 PM   #8
shibbs
Captain Gingerbeard
shibbs's Avatar
I believe the stock springs on the Vert are slightly stiffer in the rear than the coupe. I may be wrong, though.
The BMR springs are significantly stiffer than the stockers, though. To the point that the stock shocks feel slightly underdamped--but not horribly so by any means.
Old 03-06-2017, 01:18 PM   #9
The camaro show
The camaro show's Avatar
Drives: 2015 camaro 2lt
im not even lowered busted my spliter and i scraped alot too on hills
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5
Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85.
The camaro show is offline   Reply With Quote
Old 03-07-2017, 09:49 AM   #10
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Have the ASC splitter, and never had an issue prior to dropping about 1" all around with CO's. Only had the CO's on for about two weeks, too busy to drive around much, but short of curbing (which I avoid by backing in almost always), haven't had an issue yet....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
