Old 03-22-2017, 03:08 AM   #1
Inspiro
Drives: 2012 Camaro SS
TSP new L99 cams
Hi all
I read a relatively recent article in enginelabs regarding the revised TSP cams for the L99(with VVT), the most tame added a 104hp (stage 1.2) and up to around 140hp for stage 4.2
Testing was done on an engine dyno
I'm really interested in trying these, I'll probably go with 1.2 or 2.2
Has anybody tries these?
What other valvetrain mods are required with these?
Inspiro
Inspiro is offline   Reply With Quote
Old 03-22-2017, 09:08 AM   #2
Hixson
Hixson's Avatar
Drives: 2015 Camaro 1SS L99
Interesting thread - will be watching
Hixson is offline   Reply With Quote
Old 03-22-2017, 09:55 AM   #3
pir4te
Moonshiner
pir4te's Avatar
Drives: Holden SS-V L77 flex fuel
TSP new L99 cams
I doubt this has had time enough to spread never mind install since February BTW. Good to see new mainstream LS VVT developments covered in the article. In sum:
L99 with new Stage 4.2 130 HP VVT cam swap makes +100 rwhp over stock just like an LS3 similarly fitted with TSP's top spec cam. VVT performs better, broader spread, etc. No AFM because lift at valve in mid .6s.
TSP's new Stage 1.2 VVT cam, also has no AFM, makes +80 rwhp.
The company's top VVT cam with AFM makes +60 rwhp.
Compression is King.
Naturally as-pirated, all-motor, all alcohol.
pir4te is offline   Reply With Quote
Old 03-22-2017, 10:17 AM   #4
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
I'm thinking about it. I have one of their old ones installed November 2015.
What else can I do to my Camaro?
ticowarbird is offline   Reply With Quote
Old 03-22-2017, 10:51 AM   #5
sinisterlsx510
sinisterlsx510's Avatar
Drives: 14 ss camaro summit white
I want to try one of these new cams as well.. im almost full bolt ons and almost pushing 400 rwhp so hopefully if once i go cam.. ill reach at least 460 ..
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe
2019 sierra duramax 2500 all terrain x
2001 trans am
Lsx 408 ci rebuild in progress(dead project)
1967 camaro
Sbc 327.
sinisterlsx510 is offline   Reply With Quote
Old 03-22-2017, 11:24 AM   #6
butch2000
butch2000's Avatar
Drives: 2010 RS , SS , supercharged ,
wonder what they have to go with supercharger ?
butch2000 is offline   Reply With Quote
Old 03-22-2017, 03:10 PM   #7
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I need to look into these. Will they work for a L76 in a G8 GT? Still want to hop up the wife's car...
Sent from my QTAIR7 using Tapatalk
Firefighter is offline   Reply With Quote
Old 03-22-2017, 04:47 PM   #8
s13remi
Drives: 2018 Camaro SS
No, G8's are displacement on demand, not vvt
s13remi is offline   Reply With Quote
Old 03-22-2017, 04:50 PM   #9
Firefighter
I figured that out about 20 or 30 minutes after that post. Thanks for the info though. Much appreciated.
Sent from my SM-G935V using Tapatalk
Old 03-22-2017, 05:30 PM   #10
pir4te
Moonshiner
pir4te's Avatar
TSP new L99 cams
I figured that out about 20 or 30 minutes after that post. Thanks for the info though. Mu cheaper appreciated.
I have same engine as you, fitted VVT and never looked back. Costs about a grand more than cam install, and $200 via PayPal for detailed cam spec complete install instructions and directions for tune. Actual remote tune is $300 extra
HP is (to me) is the least significant benefit moving from the static stock cam, more about torque, thermals and fuel efficiency.
Old 03-22-2017, 05:35 PM   #11
Firefighter
Any links about the swap?
Old 03-22-2017, 05:40 PM   #12
Firefighter
I think I'm getting mixed up here. So the L76 is AFM and DOD. The L99 is DOD and VVT?
Old 03-22-2017, 05:43 PM   #13
pir4te
Moonshiner
pir4te's Avatar
Not specifically, I'm the only daft bugger who's pioneered it for GenIV apart from Mast I think. Sort of pushed the parameters out in developing the solution with duration and lift vs PTV and static CR, big piston reliefs, smallest chamber, highest dynamic CR for pump gas and ethanol, keeping AFM active, cam movement for Atkinson, AFM and PE, stuff like that.
I could write a book
Old 03-22-2017, 05:47 PM   #14
pir4te
Moonshiner
pir4te's Avatar
DoD is the old term for AFM. Technically G8 has AFM as does my Holden. Both have Aussie evolution of the 6.0 GenIV which does not come fitted with VVT.
L99 does have AFM and VVT fitted, is simple to retrofit to our car. Or an LS3 / LSA for that matter.
