Throttle body bolts.
So I did something stupid today. I took off my throttle body and cleaned it and I went to put it back on and snapped three of the bolts. I was using a torque wrench at 106in lbs and when I was tighting them I thought I felt the wrench click but instead the bolts snapped. I got all the rest of the bolts out. So I was wondering can I get new one's that are stronger and does Harbor freight sell them? I need them by tomorrow. Thanks all.
SoCal Race Team #13
I believe they are M6 X 1.0 45mm long
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC |
![]() Drives: 2011 2lt black Camaro Join Date: Sep 2011
They are M6-45mm bolts. You can find them at home depot or lowes if you need them local. Class 12.9 will be the strongest proof strength bolts.
Ok thanks for the info all. I'll get them tomorrow.
![]() Drives: 2015 Camaro LT Join Date: Sep 2016
Did you buy the torque wrench from Harbor Freight? I just returned one that I had purchased from them. It didn't appear to be releasing even on the lightest of settings.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
they shouldnt have broke. i think you wrench is off
#7 |
Always Workin
Drives: 2021 Mazda MX-5 Join Date: Aug 2013
I would think you'd strip the intake before the bolts break.
2023 Vivid Orange 1SS 1LE 6MT
Arrived 8/31 Purchased 9/3 2018 1SS 1LE, HyperBlue Metallic (Sold) 2014 1SS 1LE, Black, Twin Turbo (Sold) |
#8 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Damn, man...three out of four? Why didn't you stop after one or two?
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
#9 |
Ok I got the bolts from Ace Hardware. Only problem is I got 3 out of the 4 all the way in. The 4th is stripped but it's in half way. If I go to a dealer will they retap the threads or will I have to buy a whole new manifold?
#10 |
[QUOTE=Olddudesrule;9649540]Damn, man...three out of four? Why original you stop after one obrittle/QUOTE]
I thought the wrench clicked buy it was the bolt breaking. The original bolts seem weak and brittle. |
#11 |
well you will have to have the car towed or remove the manifold. dont start it. the dealer i believe will want to replace the intake when all you need is the brass insert. you should be able to find one dont know were.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
A couple of years ago when I was changing my strut brace, I needed a torque wrench rated in inch-pounds, bought one (don't remember from where but probably Harbor Freight), but when I went to tighten the bolts, it seemed I was turning them far more than I thought they needed to go, but the torque wrench wasn't clicking yet.
I finally decided to go buy one of the old-fashioned beam style torque wrenches so I could SEE the beam deflect. Worked like a champ. I still ended up turning the bolts more than I thought they would, but evidently that was because there were plastic washers underneath the heads of the bolts that were deforming as they were supposed to. I strongly suspect your torque wrench is either not working properly or you set it to the wrong setting. I know this sounds incredibly stupid, but make sure you are tightening them to INCH pounds and not FOOT pounds??? |
#13 |
![]() Drives: 2010 1SS RS M6 Join Date: Jan 2015
Harbor freight is the last place I'd buy a precision tool
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
#14 |
![]() Drives: 2013 2SS/RS Join Date: Nov 2015
For torque wrenches I use snap on, Mac, or precision instruments. As snap on and Mac get some of there's from precision. Some things you can cheap out on. Others your better off buying the best.
